Solved Running a virtual machine on windows 8.1 NOT PRO edition
LinVl
Joined
Jul 7, 2014
Hello everyone,
Young student working on my master's thesis, I have to run a few programs only available on linux.
As seen on almost all the sources I visited, I installed VirtualBox and downloaded the last Ubuntu "iso" file. after having installed the new OS on virtualbox, I tried launching it and got the very often found "VT-x is disabled in the BIOS" error.
The solution also given in all the sources I visited is "enable Hyper-V" in the "windows features turn on or off" menu. Problem is : I can't find this option (I even looked in the least probable sub directories, just in case)
I found out this feature was only available for "Pro" versions of windows 8/8.1.
My question is : Is it feasible for me to run a virtual machine, or even run a machine on dual boot on my default-installed-windows 8 machine? I don't have the money to buy the pro package (which, for some reason, is MUCH more expensive than the "previous windows to 8.1 pro" update).
and If yes : how?
Best regards and thank you for reading,
LinVl
(PS : my hardware is more than sufficient: 64bits i7-4700HQ processor, 8Gb RAM DDR3l)
    windows 8.1
    Country Flag
    Belgium
alkaufmann
Joined
Jul 2, 2013
If you get a message that VT-x is disabled in the bios, did you go through the bios? If you find an option called hyper-threading, enable it. Hope that helps.
    Windows 8.1 Pro WMC
    Masuhr - Black Corsair
    Intel I7 4770k
    ASUS Maximus VI Hero
    Corsair Dominator 16GB DD3-1866
    Asus GTX 660 Ti
    ASUS PA248
    1920x1200
    Revodrive 350 480GB
    SSD Mushkin Chronos Deluxe 240GB Sata3
    HDD WD Red 2x2TB Sata3
    Corsair 860i
    Cooler Master HAF X
    Corsair H100i
    LG G19
    Microsoft Sidewinder X8
    DSL
    IE
    MS Defender
    Logitech T650 Touchpad
    Country Flag
    Canada
    State/Region Flag
    ca british columbia
LinVl
Joined
Jul 7, 2014
Hi alkaufmann,
thanks for the fast response,
there is no "hyper-threading" options visible in the bios. but there is a "intel virtualization technology" option, which was already enabled.
    windows 8.1
    Country Flag
    Belgium
alkaufmann
Joined
Jul 2, 2013
Sorry that did not help. The only other thing I can suggest is make sure you have the latest version of Virtualbox.
    Windows 8.1 Pro WMC
    Intel I7 4770k
    Asus GTX 660 Ti
    ASUS PA248
    1920x1200
    Revodrive 350 480GB
    Corsair 860i
    Cooler Master HAF X
    Corsair H100i
    LG G19
    DSL
    IE
    MS Defender
    Country Flag
    Canada
    State/Region Flag
    ca british columbia
topgundcp
Joined
Nov 4, 2012
San Jose - California
    Name
    Dino
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
    Country Flag
    USA
    State/Region Flag
    us california
LinVl
Joined
Jul 7, 2014
hi topgundcp
For some reason, VmWare Player seems to work, unlike VirtualBox.
Thanks everyone for the help!
(btw, topgundcp, since your link sends to the procedure in order to install windows 8 on another computer, eventhough I'm sure you know it, I think it may make a confusion for people who might read the topic later on...)
    windows 8.1
    Country Flag
    Belgium
topgundcp
Joined
Nov 4, 2012
Yes, it's the tutorial for installing Windows 8 but the procedure is the same if you want to install Linux Ubuntu/Mint etc...
    Name
    Dino
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
    Country Flag
    USA
    State/Region Flag
    us california
strollin
Old Guys Rule!
Joined
Oct 21, 2010
N. Calif
I am running non Pro Win 8.1 (no Hyper-V here either) on my laptop and am able to run VirtualBox or VMWare Player without issue. Can't explain why it doesn't work for you. What version of VirtualBox were you using?
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet), W10 (laptop)
    Name
    Bruce
    Home built i7-8700K, Toshiba Satellite S55-A Laptop, MS Surface Pro 3, Dell Inspiron 15 5000
    3.7Ghz Core i7-8700K, 2.4Ghz Core i7-3630QM, 1.9Ghz Core i5 4300U, 2.8Ghz Core i5 6200U
    ASUS TUF Z370-Pro Gaming, Toshiba, MS, Dell
    16G, 12G, 4G, 8G
    Nvidia GTX 1050, Intel HD Graphics 4000
    ATI High Definition Audio (Built-in to mobo)
    Dell S2817Q 28", 15.6"
    3840x2160, 1366x768 (laptop)
    500GB ssd boot drive with 2 & 10TB Data on Desktop, 512GB ssd for laptop, 128GB SSD tablet, 500GB ssd laptop
    Corsair CX 750M
    Occupation
    Retired
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    120Mbps/6Mbps down/up
    FireFox
    MSE on desktop, Defender on laptop
    Retired after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant.
    Country Flag
    USA
    State/Region Flag
    us california
jimbo45
Joined
Sep 18, 2011
Hafnarfjörður IS
Hi there
Try this first
I've made a post about creating a portable version of Windows run as a Virtual machine from a LINUX Host.
Try running that first -- that will test whether the machine is capable of running VM's or not.
Don't activate the Windows VM though if you want to run the windows system as the HOST and not the VM.
http://www.eightforums.com/installa...make-portable-windows-system-any-version.html
If this works then your machine is perfectly capable of running VM's so we need to check out another solution.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
    Country Flag
    Iceland
LinVl
Joined
Jul 7, 2014
Hi jimbo45
Sorry, I didn't try your method since I managed to run a linux on my computer with VMware. (and the programs I need do run correctly!)
thank everyone for the help!
    windows 8.1
    Country Flag
    Belgium
