Solved RunDLL (Not Responding) message box at every startup
wondermuse
:( I get this RunDLL (Not Responding) message box every time I restart the computer. The rest of the message says "There was a problem starting C:\Users\SHERRY\AppData\Local\Conduit\BackgroundContainer\Background Container.dll The specified module could not be found." I have included a snip .png of the message box.
I found a help page searching online, but it was totally useless. I will attach this information as a .pdf file, if interested. The files instructed to be deleted in the 'regedit' would not delete at all. And I still don't know if I was intended to delete the the entire folder with sub-folders, but since they couldn't be deleted it doesn't matter. These folders and the files listed in them did not seem to have anything to do with Conduit Ltd. A couple of these 'Regedit' folders were not even listed.
I'm still searching online, but this help page seems to be the only one that deals with my specific RunDLL message box at startup. that being the Conduit Ltd.
  • RUN DLL FIX IT.pdf
    HP PAVILION 23-b010
    1.7 GHz Dual Core AMD E2-1800 APU
    Pegatron Corp. 2AF0 (P0) AMD A40/A50 Series FCH
    6 GB Ram
    AMD Radeon HD 7340 Graphics
    C:\
    wireless
    wired
    1-5 Mbps
    AVG Free Version
XweAponX
It's that Conduit program that is the basis for some toolbars. Conduit is not bad in itself, but it has been used as an exploit to make malware toolbars.
Just uninstall all conduit programs, most likely yout Antivirus deleted part of it so now you got this.
If the installer does not work, just look in your Program Files folders and delete any Conduit folders in there as well.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
xunile
You might also want to check the Task Scheduler to see if the Backgroundcontainer is trying to run from there. Sometimes even after you uninstall all of the conduit junk it still remains in the Task Scheduler.
    Windows 7
wondermuse
To xunile:
:D Thanks a lot, that did it.
    HP PAVILION 23-b010
    6 GB Ram
    C:\
    wireless
    wired
    1-5 Mbps
    AVG Free Version
