Solved router not passing port scan after opening port
24
so i opened my port 25565 (or so i thought) went to test to see if its open on multiple sites and....all of them say its closed. :confused:
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    realtek hd integrated
    1366 X 768
    seagate hybryid 500gb
    firefox
    windows defender & comodo firewall
TairikuOkami
Be nice to all, please?!
Trnava
683
Start the application you opened the port for and then test the port, it should report it as opened.
    Win 8.1.1 Pro x64
    Lenovo E525
    AMD A4-3300M @ 2,0GHz
    6GB DDR3 1333MHz
    AMD Radeon HD 6480G 512MB shared
    Creative Sound Blaster X-Fi Surround 5.1
    1366x768
    WD 465GB
    Fusion Tweaker
    Logitech K360
    Logitech M705
    50/50 MBps
    Yandex
    No AV & No Firewall
    Headphones: Sennheiser RS170
24
still timmed out, i can connect to the server im trying to run via localhost but not via external ip's
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
24
i also added an exception in windows firewall for inbound tcp and udp on the port to be sure and got the same results.
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
topgundcp
San Jose - California
2,847
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
24
[/QUOTE]Try to set Local port: All Ports for both TCP and UDP[/QUOTE]
in windows firewall where is this at i looked around a while
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
topgundcp
2,847
From Windows Firewall. Here's a setup for Utorrent as an example:
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
24
#8
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
jimbo45
Hafnarfjörður IS
4,373
#9
Hi there
That application has to send back data and it could be your ISP is blocking the INBOUND reply. Try using another port checking service.
Incidentally some ISP's block port 80 (done to stop people from creating open public server systems from domestic computers) so you'll probably need to allow 8080 instead (or as well).
There's no problem in allowing REMOTE access to a home machine - but what ISP's usually want to stop is people running full busy PUBLIC SERVERS with a lot of queries on a home computer. With today's broadband speeds it's quite feasible now in a lot of cases !!).
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
24
#10
Hi there
Cheers
jimbo
that screenshot just shows port 80 because it resets once you refresh the page, the port im trying to use is 25565. i am trying to run a public server but not a large one, just a small one for a few friends.
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
24
#11
just a quick update i have not changed anything requarding outbound ports, i am trying to run a minecraft server and the only port it uses is 25565 from numerous searching ive done online. i do have acces to my router and here are the logs. i may need to try to run the server again because when i did a search for the port number the logs only had one result. also is there a different way to check ports other than online scanners? also needlessto say ive tried this with comodo and windows firewall turned off.
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
topgundcp
2,847
#12
For testing purpose. Why don't you try with regular Windows Firewall instead of Comodo. Third party Firewall is only good for controlling outbound
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
24
#13
yeah i use comodo to controll outbound of some software otherwise i'd use windows firewall.
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
jimbo45
Hafnarfjörður IS
4,373
#14
Hi there
For TESTING it's usually best to turn the entire wretched thing (firewall) OFF.
My experience - especially with my background as an Engineer is to test ONE THING at a time and then gradually add the other pieces --if you test the whole kybosh together it's hard to diagnose the cause of the problem - whether it's the firewall, the router or Windows itself or even the interaction between all 3.
I've seen it so many times where people make several changes AT THE SAME TIME to their system and then whine "It doesn't work - what do I do now" - and of course they haven't taken a backup either !!!.,
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
broe23
Retired from the grind
Central IL
3,468
#15
Get rid of Comodo, turn off Windows Firewall, since you are behind a router. Your issue may be that the port is being stealthed by the router, is why it shows closed. If the router has UPnP enabled. It will trigger the port as needed, when queued by the application to open and close the port.
What does the GRC.com Port scan show? Now a lot of ISP's are block any type of P2P & Torrent software, so that it does not steal bandwidth from other uses.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
24
#16
ive turned both off and run the server so the port will be triggered and still no luck :/ i would like to use a different port scanner but i wasnt able to locate the port scanner on the grc site. can you give a direct link.
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
broe23
Central IL
3,468
#17
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
24
#18
Services, then Shieldsup!, then click on Proceed, then choose "All Service Ports" at http://www.grc.com . You may have the port setup off somewhere. You can go through a double check with the info at Free Help Forwarding Ports - PortForward.com .
got the response that "THE EQUIPMENT AT THE TARGET IP ADDRESS
DID NOT RESPOND TO OUR UPnP PROBES!" im assuming this means that this router is blocking access to ports on its own without me using any firewall. also i used that guide to check i portfowareded correctly before making this thread
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
24
#19
heres a netstat i did, 25565 is listenning on tcp
    win 8.1
    toshiba a665-s6070
    intel core i7
    8gb crucial
    nvidia 310m
    1366 X 768
    firefox
broe23
Central IL
3,468
#20
DID NOT RESPOND TO OUR UPnP PROBES!" im assuming this means that this router is blocking access to ports on its own without me using any firewall. also i used that guide to check I port fowarded correctly before making this thread
No it means that your router is doing its job as it should be. It means that UPnP is not enabled as it should be.
You could try the Trigger option and see if that works, vs. doing the complete open the doorway for the port on the router.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
