Robocopy and same directory
balubeto
Hi
With the Robocopy command of Windows 8.x, how do I do a copy of a file (renaming it) in the same directory of the source file?
Thanks
Bye
adamf
Banned
You can't. Use copy or xcopy if you want to rename.
e.g.
xcopy c:\test\old.txt c:\test\new.txt
Note xcopy will always prompt you with "Does c:\test\new.txt specify a file name or a directory name on the target" so you would probably be better off with
copy /v c:\test\old.txt c:\test\new.txt
where the /v verifies the copy.
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
