"Right click > Open with" doesn't work properly.
Syncopator
U.K.
99
Right clicking a GIF or PNG file and telling the system to open it with Paint Shop Pro brings up the message
"This app can't run on your PC
To find a version for your PC, check with the software publisher."
However, if I open Paint Shop Pro I can drag and drop either a GIF or PNG into it and they open ok.
Is there a way to get the "Open with" to work?
    HP 110-412na
Berton
Forever West
591
I'd wonder if the message isn't actually referring to the .exe file for the program, have seen infections cause it.
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    2 Customs and 3 OEM/Brands
    AMD and Intel
    2 Acers & 1 Antec[?]
    i7 in 2 Acers, i5 in desktop
    Desktop w/Gigabyte
    Two w/16GB, 1 w/8GB
    Laptops GameWorthy; Desktop maybe GameWorthy
    flatscreens; 2 are BluRay worthy
    1368x768; 1600x900
    1TB internals; 2 ext usb WD 1TB HDs
    what's PSU?
    Regular plus external fans
    desktio w/PS2
    desktop w/PS2
    DSL middle level [160?]
    from Netscape 0.9 to FF 36
    well-balanced, well-configured mult-layered defense is best
    From MS-DOS 3.3, MS-DOS 6.22, from Windows 3.1 to WFW 3.11 to Windows 95-98SE, now to Windows 7 Pro.
    Security for now: Windows 7 Firewall, Emsisoft AM, MSE [scan-only], SpywareBlaster, Ruiware/BillP combine
Syncopator
U.K.
99
No. As I said in my first post I can open Paint Shop Pro.
w8f techs, how do I download OpenWithAdd.zip as named in a sevenforums tutorial?
Open with - Add Program - Windows 7 Help Forums
I know this is Windows 8, however, I thought that tutorial should also work for Windows 8.
Thank you Roland, that has worked in Windows 8.1.
    HP 110-412na
    Desktop w/Gigabyte
    Two w/16GB, 1 w/8GB
    1368x768; 1600x900
    what's PSU?
    desktio w/PS2
    desktop w/PS2
Syncopator
U.K.
99
Although the problem was solved, it has reappeared - don't know why.
When I click on Register, after entering the path top the required file, I now get a window saying "An error occurred... -2147024891"
The comment/feedback link on the author's site doesn't work and I see no other method of making contact with him.
Is anyone familiar with the program and know what that error message means?
    HP 110-412na
