right click and then "search tutorials"
MilesAhead
Eclectician
2,130
Has anyone figured out how to highlight text, right click and then "search tutorials" in context menu? That would save a lot of time. So many fixes are in there. :)
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
Not tutorials but internet search.
a picture:
Edit---
Highlight & search:
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
24,170
Hey Miles,
Nar, but you could also do a Google search from within Tutorials to search for them.
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Edwin
1,759
My Computers
System One System Two
    Windows 7 Home Premium
    HP Pavillion
  • PC2
    Tablet - Windows 10 Home
ARC1020
446
A few years ago Microsoft removed the feature to create Internet Explorer Custom Search Providers from their website, which was a really stupid decision. Why remove such a useful feature??? However, a third party website allows you to still create them and therefore you could create a Custom Search Provider to do what you describe.
1) Go to EnhanceIE.com - IE7 Search provider builder
2) Insert www.eightforums.com/tutsearch.php?q=TEST in the URL box
3) Insert Eight Forums in the Search Provider name box.
4) Click install button
5) Click 'Add' button
Note:
If you want to search directly in Google or Bing you could alternatively use the following URL's in step 2 instead of the eightforums link, however the search results won't be strictly limited to the tutorial sections, instead it will include any pages that contain the word 'Tutorial' in them as well as the search term:
https://www.google.com/search?q=site:eightforums.com+tutorial+TEST
https://www.bing.com/search?q=site:eightforums.com+tutorial+TEST
Note: As the eightforum tutorial search feature utilises Google, if you have Google blocked in one of your Tracking Protection Lists, you'll need to have Tracking Protection turned off on the Eight Forums site in order for it to work.
To remove the Search Provider you've just added, go to Tools > Manage Add-ons > Search Providers, select the search provider and click 'Remove'.
    Win 8 64-bit
MilesAhead
Eclectician
2,130
Hey Miles,
For some reason I overlooked that one. I kept using either top right corner or "search this category." Neither of which seemed to hit what I wanted. But I'll go with this one.
Edit: One weird thing I noticed. FF 30.0 32 bit just hangs when I search using that search line. Works fine in Opera.
Edit2: I just tried FF30.0 in the equivalent search line on W7 forum and it worked normally. Strange.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
