Replacement Start Menus - Consensus of opinion
Mustang
Australia
716
I have been a big advocate of Ex7For8 to restore the traditional Win7 Orb Start Menu, and up until recently it had been OK. But after installing a batch of recent updates, on start up it takes about 30 seconds after the desktop appears before any apps can be run. And when I click on an app/program it takes another 30 seconds to open it.
Once any given app/program has been opened once, it re-opens next time at normal speed. This only happens when boot is straight to desktop which is running Windows 7 Explorer shell. If boot is to Metro, all apps/programs open instantly. So it seems Ex7For8 has run it's course of usefulness.
Is there a consensus of opinion as to which is the best restoration start menu, and which one most most closely resembles the original Win7 Orb Start Menu?
Or are there as many preferences as there are alternative start menus?
I'm currently running StartIsBack in trial mode and it seems to have fixed the problem.
What I want to know is if this is running Explorer 7 or 8?
And has anyone encountered problems with it?
And how much it costs after the trial runs out?
    Windows 7 Ult Reatil & Win 8 Pro OEM
    Built as DIY
    6 core 12 thread & 4 core
    Inel Extreme & Intel standard
    12GB & 8GB
    3 top end SLI linked & onboard
    In built in graphics card & onboard
    24 & 23 inch Samsung LED backlit
    High def
    Corsair Force 128GB SATA3 SSDs in each machine. Plus several external USB3 and eSATA spinner HDs
Mustang
Australia
716
    Built as DIY
    12GB & 8GB
    High def
Wenda
Classic Shell is free. And very good.
I put it on my Win 8 setup, mainly for consistency with my other OSes.
But I find that I'm not using it that much, and could probably remove it.
Quick-Launch, on the other hand, is a different story. It isn't going anywhere.
A task-bar and/or desktop full of crap isn't going to happen here. (Yes, I do
use the Start Screen).
Wenda.
    Windows 8.1 'Ultimate' RTM 64 bit (Pro/WMC).
    Acer AS8951G 'Desktop Replacement'.
    [email protected]/3.1Ghz.
    Acer
    [email protected]
    GeForce GT555M 2GB DDR3
    Realtek HD w/Dolby 5.1 surround.
    Built-in. Non-touch.
    18/4" 1920x1080 full-HD.
    Toshiba 750GBx2 internal. 1x2TB, 2x640GB, 1x500GB external.
    Stock.
    Laptop.
    Stock.
    Full 101-key
    USB cordless.
    IE11, Firefox, Tor.
    Windows Defender, MalwareBytes Pro.
    BD-ROM drive.
Mustang
Australia
716
@ Wenda. Thanks for input. I did try Classic Shell in earlier testing, but I prefer something that duplicates as closely as possible Win7 Orb Start Menu.
I can live without a legacy start menu and use start screen and create tool bars to AppData, User, Programs; and replace jump start menu with icons attached to taskbar, but it's all there in Win7 Orb ready set up. And quicker to use than the above.
Since I don't use Metro apps, and work entirely on desktop, I want something that boots straight to it. And don't wan to jump off desktop to access start screen.
Horses for courses of course! No pun intended, it's not Randwick already!
Cheers :)
    Built as DIY
    12GB & 8GB
    High def
Wenda
@Mustang: - Not a problem, mate. All good.
Wenda.
    Acer
    [email protected]
    Stock.
    Laptop.
    Stock.
    Full 101-key
    USB cordless.
    IE11, Firefox, Tor.
    BD-ROM drive.
xpclient
Classic Shell tester
62
You mean you want the Windows 7 orb? You can change it. Right click Classic Shell's Start button -> settings -> Start button tab -> Pick custom. Download image from http://i.imgur.com/ObwKE.png and set it as Start button image.
    Microsoft Windows
    I do the testing and give feedback on User Experience and ideas for Classic Shell.
Hopachi
Polyhedric Stellation
Orbiting the Moon
2,975
#8
I don't use any menu anymore. If I do, I use one that works great, opens fast and is responsive. It doesn't need to be 100% identical to the original one from Win7: that one is gone and nobody can bring it back as it was (the real File Explorer process is the one that should do the job... no hack is needed here).
I used the menu a lot, the one that came with Win98 for example. But the vista one included search, I got used to that.
As it took me some time to get used to the menu, it took me some time to forget it again.
It's pretty sad to see someone attach to an interface that will probably chance as the ideas and programmers change as well.
I was using Classic Shell and will still use it when the need is high. But it seems we have a lot of choice lately.
Cheers
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
TONSCHUH
Wynnum Australia
466
#9
I use Start8 on all my machines and it works flawless so far.
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
885
#10
Classic Shell, of course.
    Win8.1 Pro, Desktop Mode
    Me
    AMD FX-8150
    Gigabyte GA-890GPA-UD3H
    8.00 GB Dual-Channel DDR3 (9-9-9-28)
    AMD Radeon HD 6570
    Creative X-Fi Titanium
    PX2710MW
    [email protected]
    1x1TB Western Digital WDC WD1001FALS-00J7B1 ATA Device Caviar Black -
    4 x 2TB Seagate ST32000542A -
    1 x 4TB Seagate External
    Antec
    Noctua NH-D14
    Logitech Illuminated Keyboard K740
    60meg cable
    Cyberfox
    AVG Security Suite
241
#11
The post opener asks for an opinion.
The old adage you can't teach an old dog new tricks isn't valid. I love new tricks.
The problems I have in amending Windows 8 from it's origin, with 3rd party software, is that it is just that - amended, modified. Although I'm happy to hear that some users are not experiencing problems with the amended start menu, for myself Windows 8 already has enough problems on it's own and lots of defects that haven't already been remedied yet.
There can't be any doubt that introducing and installing such software changes lots and lots of parameters. It's intrusive, it does things to the registry, it will void warranty's, it will go out of the mainstream of trouble shooting and fixes designed by Microsoft.
Personally I like Windows 8 Metro. It's much easier for me than the classic style. Further I have a second touch pad keyboard that I use to practice the finger movements.
    HP
norepli
386
#12
Most programs make some changes to the registry so what makes these Start Menu/Button programs so unique that "their" specific changes would cause a "void in warranty?"
smurfercom
60
#14
As mentioned in an earlier post StartisBack uses the original W7 coding that was left behind in W8 and it is the real deal, no issues with boot times and is not affected by updates. I'm surprised you haven't already tried it, it has a 30 day trial.
I have no idea what he is talking about, loading a prog will not void PC warranty's especially OS warranty's if you build your own lol! He seems to be a hardcore advocate of the Metro clutter and charms bar kludging.
    W8 Inspiron 17R W8P+MCE HTPC
    Custom HTPC systems builder, trouble shooter for Apple and PC products.
    My HTPC specs:
    Core i5 W7 Pro/W8 Pro+MCE
    Lian Li blk mid tower 10 gigs + 2 OS HDD's W7/8.
    Gigabyte UD3 mobo P55 chipset.
    Workstation:
    Same as above but using the "M" series mobo with ATi 5670
    Dell Inspiron 17R i3 3rd gen W8.
    Nokia Lumia 810 W Phone8.
Hopachi
Orbiting the Moon
2,975
#15
What is this all about? I don't see what program... it can be a bad program.
EDIT: I guess he talks about the Ex7forW8 mod found in the OP's post.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
znod
2,156
#16
All I want to do is to "replace" the functionality "lost" when MS decided not to have a Win8-relevant start menu. I don't want to use an alternative that changes the way Win8 works if possible. In this regard, I don't want to use anything that will cause much of a system drain.
So, what is best for me is to use the taskbar-toolbar approach. See snip below. My Apps toolbar contains a few more items one would need to be able to scroll to see. It contains a shortcut to everything I might conceivably want to access from a start menu (and actually to some I items I am not using at all right now). I could prevent the possibility of having to scroll by omitting a few never, or virtually never, used items. And, of course, I shore some things up using desktop icons (which I use a great deal) and pinned-to-taskbar apps. One of my pinned items is the all apps shortcut (i.e., goes to all apps in metro) covered in our tutorials.
Note that my snip shows a Programs toolbar also. I don't use it; just made it to see how it works given a tutorial that deals with such. Also, note that folders can be placed in taskbar toolbars for categorization or whatever. And, for categorization, several toolbars can be used if one wants.
In sum, what works for me is something that really doesn't change Win8, but still gives me what I need.
FYI, note that I am running the Win8 installation in my snip virtually from my MacBook Pro using Parallels. It works a treat.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
znod
2,156
#17
Not an issue.
    EVGA 570 SC
    Gateway
    Dual Boot:
Hopachi
Orbiting the Moon
2,975
#18
Doesn't the toolbar drain anything from speed at start-up (list gets loaded and refreshed on click)?
By the way: nice wallpaper.
Is it Mount Fuji?
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Ztruker
I use Start8 from Stardock and have had no trouble at all. Look and feel is exactly like Win 7 which is what I want (for now).
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
znod
2,156
#20
Is it Mount Fuji?
Thanks on the wallpaper. And, Fuji, not sure, but it looks like it. I am sure the toolbar requires use of some system resources, but I'd think not as many/much probably as a third-party start-menu replacement. I have never noticed any kind of a startup slowdown, but that would be pretty much impossible to document anyway. I never notice a delay when accessing the toolbar virtually, but, on my brick and mortar Win8 installation, I sometimes note a small delay in accessing it.
    EVGA 570 SC
    Gateway
    Dual Boot:
