Repeated DRIVER_POWER_STATE_FAILURE BSODs
ng2
First time posting on this forum, so please bear with me.
I've had 4 BSODs since 06/06/15 including 3 in the last 3 days due to DRIVER_POWER_STATE_FAILURE. I don't see any particular pattern between when these occur except for that the last 2 times it happened about 5-10 minutes after my laptop is brought out of hibernation/ booted up from off; but it doesn't happen every time. Also, its happened at least twice when watching Sky Go through a HDMI cable connected to my TV.
My system's information collected using the DM Log collector Tool is attached to this post.
Any help would be much appreciated, and if any more details are required please let me know.
blueelvis
OMG Debugger!
Hi ng2 & Welcome to the forums ^_^,
Unfortunately, the ZIP file attached by you is empty and hence does not contain any minidump files for us to analyze :( . Could you please re-run the utility and upload the ZIP file again (Please make sure that it is not empty).
-Pranav
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
axe0
BSOD Kernel Dump Analyst
Hi ng2,
I just went through the files and I'm wondering why your hosts file is empty.
Further please update or remove following drivers as they are flagged
Nvidia Video Driver
*** WARNING: Unable to verify timestamp for [COLOR=#ff0000]nvlddmkm.sys [/COLOR]
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
[url=http://www.nvidia.com/Download/index.aspx]Drivers - Download NVIDIA Drivers[/url]
Comodo Safe Backup Driver
*** WARNING: Unable to verify timestamp for [COLOR=#ff0000]CBUFS.sys[/COLOR]
*** ERROR: Module load completed but symbols could not be loaded for CBUFS.sys
[URL]https://support.comodo.com/[/URL]
When you've updated the Nvidia drivers I recommend to read this thread, because it could solve other possible coming BSOD's.
Recommended to update following drivers
Western Digital SCSI Arcitecture Model (SAM) WDM driver
[COLOR=red][B]wdcsam64.sys Wed Apr 16 10:39:08 2008 (4805BB2C)[/B][/COLOR]
[url=http://support.wdc.com/product/download.asp]WD Support / Downloads[/url] or [url=http://wdc.custhelp.com/app/answers/detail/search/1/a_id/5419#]WD SES driver download and instructions for recovering the WD SmartWare installer[/url]
Realtek HiDefinition Audio driver
[COLOR=red][B]MBfilt64.sys Fri Jul 31 05:40:32 2009 (4A7267B0)
[/B][/COLOR][URL]http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false[/URL]
 The following information contains the relevant information from the blue screen analysis:
**************************Tue Jul 14 17:58:05.147 2015 (UTC + 2:00)**************************
Windows 8 Kernel Version 9600 MP (8 procs) Free x64
System Uptime:[B]2 days 20:24:00.020[/B]
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, ffffe001bae407e0, fffff80401139960, ffffe001c2db2010}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000009F"]DRIVER_POWER_STATE_FAILURE (9f)[/URL]
Arguments:
Arg2: ffffe001bae407e0, Physical Device Object of the stack
Arg3: fffff80401139960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe001c2db2010, The blocked IRP
BUGCHECK_STR: 0x9F
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
FAILURE_BUCKET_ID: [B]0x9F_3_ACPI_IMAGE_pci.sys[/B]
CPUID: "Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz"
MaxSpeed: 2400
CurrentSpeed: [B]2394[/B]
BIOS Version 4.6.5
BIOS Release Date 06/26/2013
Manufacturer Notebook
Product Name P17SM
**************************Sat Jul 11 21:32:50.538 2015 (UTC + 2:00)**************************
System Uptime:[B]15 days 22:19:35.427[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
BugCheck [B]9F, {3, ffffe00037db7060, ffffd000e72db960, ffffe0003f9762d0}[/B]
Arguments:
Arg2: ffffe00037db7060, Physical Device Object of the stack
Arg3: ffffd000e72db960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe0003f9762d0, The blocked IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Thu Jun 25 20:59:07.927 2015 (UTC + 2:00)**************************
System Uptime:[B]5 days 13:05:47.308[/B]
BugCheck [B]9F, {3, ffffe000ca395880, ffffd001e509b960, ffffe000d663e180}[/B]
Arguments:
Arg2: ffffe000ca395880, Physical Device Object of the stack
Arg3: ffffd001e509b960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe000d663e180, The blocked IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Thu Jun 18 19:03:55.598 2015 (UTC + 2:00)**************************
System Uptime:[B]1 days 20:44:54.340[/B]
BugCheck [B]9F, {3, ffffe0016f271880, ffffd000f2047960, ffffe00172c8c680}[/B]
Arguments:
Arg2: ffffe0016f271880, Physical Device Object of the stack
Arg3: ffffd000f2047960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe00172c8c680, The blocked IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Tue Jun 16 19:03:09.661 2015 (UTC + 2:00)**************************
System Uptime:[B]0 days 19:34:47.400[/B]
BugCheck [B]9F, {3, ffffe0000f84c060, ffffd000a91f9960, ffffe00012bfe010}[/B]
Arguments:
Arg2: ffffe0000f84c060, Physical Device Object of the stack
Arg3: ffffd000a91f9960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe00012bfe010, The blocked IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Mon Jun 15 22:19:13.811 2015 (UTC + 2:00)**************************
System Uptime:[B]0 days 1:24:59.583[/B]
BugCheck [B]9F, {3, ffffe000027fa060, ffffd001e637f960, ffffe0000740ce10}[/B]
Arguments:
Arg2: ffffe000027fa060, Physical Device Object of the stack
Arg3: ffffd001e637f960, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe0000740ce10, The blocked IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Sun Jun 14 20:57:16.814 2015 (UTC + 2:00)**************************
System Uptime:[B]7 days 22:02:49.985[/B]
BugCheck [B]9F, {3, ffffe0018ec0d060, ffffd00076662cb0, ffffe001956e12a0}[/B]
Arguments:
Arg2: ffffe0018ec0d060, Physical Device Object of the stack
Arg3: ffffd00076662cb0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe001956e12a0, The blocked IRP
BUGCHECK_STR: 0x9F
PROCESS_NAME: firefox.exe
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Sat Jun 6 22:53:24.960 2015 (UTC + 2:00)**************************
System Uptime:[B]2 days 3:06:40.675[/B]
BugCheck [B]9F, {3, ffffe001437bf060, fffff80192f77cb0, ffffe00146be5490}[/B]
Arguments:
Arg2: ffffe001437bf060, Physical Device Object of the stack
Arg3: fffff80192f77cb0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffe00146be5490, The blocked IRP
BUGCHECK_STR: 0x9F
PROCESS_NAME: chrome.exe
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
**************************Tue May 26 18:18:11.138 2015 (UTC + 2:00)**************************
System Uptime:[B]7 days 22:31:42.094[/B]
*** WARNING: Unable to verify timestamp for CBUFS.sys
Probably caused by :[B]CBUFS.sys ( CBUFS+1a24 )[/B]
BugCheck [B]50, {ffffc001d6984000, 0, fffff803e57584c9, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000050"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: ffffc001d6984000, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff803e57584c9, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR: AV
PROCESS_NAME: TiWorker.exe
FAILURE_BUCKET_ID: [B]AV_CBUFS+1a24[/B]
MaxSpeed: 2400
BIOS Version 4.6.5
Product Name P17SM
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
