Solved Remote Desktop control
gallicbear
109
Hi! Don't know under which subcategory to post this.
Can remote desktop control be achieved without 3rd party programs, just with Windows settings? Trying to connect with possibly 2 PCs running Windows (not at the same time), via the Internet. So I need to connect via the WAN, not with PCs on the same LAN. Thanks in advance for any tip.
    XP, Vista, Windows 7, Windows 8/ 8.1, Windows 10
alphanumeric
slightly off center
Gold Member
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
alphanumeric
slightly off center
Gold Member
I can remember trying to do it on two Windows 7 Home Premium PC's and it wouldn't work. The host had to be 7 Pro for you to be able to remote in to it. I think it was the host? Anyway looks like you've got some reading to do.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
gallicbear
109
Thank you. Since then I also found a program called TeamViewer, and I put it to work. It has a free license and I like it! I'll do more of the reading when I've got more time.
alphanumeric
slightly off center
Gold Member
:thumb:
    Asus
    Thermaltake TR 620
    Stock heatsink fan
