Reliability Monitor Not Working W8 Pro Desktop
garry
2
Hello, can you help please, my reliability monitor is not working, it runs as per the schedule but does not produce any data, my problems started recently following a small corruption with the library docs, this corruption caused the R/monitor to run continuously, I rectified this error with a library scan, all is good there, I then ran the reliability reset batch file which reset the monitor back to zero. However when the monitor runs it does not produce the required files that live in the C:\ProgramData\Microsoft\RAC folder under C:\ProgramData\Microsoft\RAC\PublishedData and C:\ProgramData\Microsoft\RAC\StateData, these 2 folders are empty. I saved the original files however if I return the files to the 2 folders the reliability monitor does not access them. I have attached 2 x prints one of my RAC registry and RAC WMI.
I have also attached prints of my Task Scheduler Conditions, Settings and Triggers. I have searched high and low for a solution to fix this issue, I do not want to run a Windows refresh as I have numerous installed programs that I would have to reinstall. Hope you can help, please let me know if you require any further info, Many Thanks
Note: Do you think an update to 8.1 may fix this issue. We are due for release in Australia on the 17th Oct.
    W8 Pro
    Custom Build
    E8400 Core 2 Duo
    Gigabyte EP35-DSP3
    Kingston 2 x 4 gigabytes
    Nvidia Geforce 9600GT
    IE10
    Norton 360
my2cents
Veni, Vidi, Vici
2,191
Hello garry,
I cannot identify your current issue; however, I can confirm that feature works on Windows 8.1 RTM
(fully activated):
Hope this information is helpful. Cheers!
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
garry
2
Thanks for your reply, is there any way thru. this forum that I can refer this to a Microsoft rep. to have a look at?
    W8 Pro
    Custom Build
    E8400 Core 2 Duo
    Gigabyte EP35-DSP3
    IE10
    Norton 360
my2cents
Veni, Vidi, Vici
2,191
No, you would have to go to Microsoft directly yourself. This forum is not directly affiliated with Microsoft.
    Intel G2020
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
