reinstall on second hard drive -- product key issue
shmu
I tried to reinstall windows on a second hard drive, but it won't accept my product key, assumedly because I am already using it for the current windows installation on the first hard drive.
How do I transfer my license to allow a reinstallation on the second hard drive? That's the best option, so I can go back to the first drive if I want to.
Second option:
If I wipe the current windows partition clean, will that enable me to reinstall on the second hard drive?
    windows 8.1 pro
Wullail
Active Member
Unless you want to get a clean copy , you could always put the 2nd hard drive on your system and clone it onto your 2nd disk using many freeware programs.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
shmu
I want a clean reinstall.
what if I unplug the first drive when I install on the second drive?
then will it accept my product key?
    windows 8.1 pro
alphanumeric
slightly off center
Gold Member
What do you mean by "won't accept my product key"? More specifically where and when in the install process do you get that message? The exact message your getting would help. The key shouldn't be blocked when installing on the same hardware it was originally used on. I've done numerous reinstalls on my PC's with no problems using the same key over and over again on that PC. Even after swapping out hard drives. Are you using clean unmodified install media, obtained from a reputable source?
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
shmu
I am using the iso image provided by microsoft when I bought my windows8 pro 32 bit.
I am installing by flash drive.
right at the beginning of the process, before it does anything, it asks for my key. and the key doesn't work. I can't get to square one with the installation.
    windows 8.1 pro
alphanumeric
slightly off center
Gold Member
What's the exact wording of the refusal message? It sounds like you are mistyping in the code. Example typing a B when it should be an 8. I would double check your product code to be sure you have it read and written down correctly. Where your at, I don't believe it has done any activation check yet so its not that. Also make sure your not using a Media Center key, they won't work for installation, they only work in Add Features.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
shmu
thanks for the tips, next time I try I will look out for these things.
    windows 8.1 pro
alphanumeric
slightly off center
Gold Member
Good luck, hopefully you get it sorted. If you don't, please note the error message as that may tip us off to what's happening.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
shmu
in reply to theog:
I already succeeded in my dual boot mission (i.e., the other thread), albeit the long way around. with a better boot-fix-it disk, I probably could have made life a lot easier.
Now I am trying something a little more modest: simply to install windows on a second hard drive. I seem to remember that windows has a way of snooping around your computer and checking if you already have an existing installation, and if so, sorry: only one installation per computer. Is that not so?
    windows 8.1 pro
theog
Gold Member
So you are trying to install & Activate Windows 8/8.1 three times.
3 times = 3 Product keys.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
alphanumeric
slightly off center
Gold Member
in reply to theog:
No, not that I'm aware of. The Activation server keeps a record of what PC a Product code was activated on. Think of it as a hardware finger print. If it see's a second PC with different hardware using the same Product code it will likely block the second PC from activation. This all happens after installation. During installation Windows will look for a previously installed OS, but that's for situations were you want to fix the currently installed OS or setup a dual boot. As far as I know it doesn't go checking product codes etc of the previously installed OS during installation. Not unless Microsoft has changed things recently.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
SIW2
Team Member
Not sure why you are having that trouble. You can have two installs on the same machine if you want. Different partitions or hard drives or virtual hard drives should all be fine.
You only need one one product key as long as you only have one booted up at a time.
Perhaps you should try the default product key to get the thing to install:
CoreSingleLanguage=Y9NXP-XT8MV-PT9TG-97CT3-9D6TC
Professional=XHQ8N-C3MCJ-RQXB6-WCHYG-C9WKB
Core=334NH-RXG76-64THK-C7CKG-D3VPT
You may then need to enter your purchased key to get it to activate.
    7/8/ubuntu/Linux Deepin
shmu
yep, that's what I thought.
but the clone-turned-dual boot did not have an activation problem, though.
question is: if I take out the drive with the other windows installation, will that work? I mean, then windows doesn't know I have an old dusty hard disk sitting around in my drawer, right? After all, I am allowed 1 windows installation on my computer, I would assume.
    windows 8.1 pro
Wullail
Active Member
It won't install twice on the same PC as the same key will already be used there...
Remove the original drive and install on the 2nd drive will be the only way around this.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
shmu
right. it worked. but then after windows successfully installed, and it wanted to activate, it would not accept my product key at that point.
    windows 8.1 pro
Wullail
Active Member
Did it say what was wrong ? , invalid key or it just wouldn't activate?
if it's the later , use the phone activation option.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
NiFu
Ofcourse. If you use two licences.
Licence agreement says:
1. License Rights and Multi User Scenarios
a. Computer. In this agreement, “computer” means a hardware system (whether physical or virtual) with an internal storage device capable of running the software. A hardware partition or blade is considered a computer.
So I interpret this: Two (bootable) hardware partitions = two computer = two licences necessary
shmu
quite true. cloning is not detected, but reinstallation on a different drive is normally detected and is considered worthy of another license..
    windows 8.1 pro
SIW2
Team Member
In that case, anybody using windows system image better get another license. That is a .vhd.
Strange how MS provide windows system image for you.
You can either boot your regular installation,or you can boot the .vhd file. You only have one instance, i.e one occurrence, i.e one at a time.
