Regular Maintenance always arms itself again and wakes PC
dfgfgd
50
I have a really frustrating problem, that Windows 8.1 always wakes my PC from standby at some point. I looked up with powercfg /waketimers:
Der von [SERVICE] \Device\HarddiskVolume4\Windows\System32\svchost.exe (SystemEv
entsBroker) gesetzte Zeitgeber läuft um 03:49:17 am 20.03.2014 ab.
Ursache: Die geplante Aufgabe "NT TASK\Microsoft\Windows\TaskScheduler\Regular
Maintenance" wird ausgeführt. Hierzu muss der Computer reaktiviert werden.
If I disable it or deactivate the option for it is allowed to wake the PC to run (see screenshot), the entry showing up with powercfg /waketimers changes to:
Im System sind keine Aktivierungszeitgeber aktiv. (no entrys)
But here it comes: the task always reactivates itself and arms itself with the option to be allowed waking the PC, and the PC always wakes up at night around 3am doing this stupid maintenance.
What is causing this? Why is it overwriting itself again after some time, and how can I disallow/deactivate this.
dfgfgd
50
It doesnt matter switching the option off you mentioned, thats something totally different related. And disabling globally "allow wake timers" isn't an option, because I need some of them to work (for example for DVB programings), but I dont want the Windows maintenance one to wake up the pc, but it always arms itself again (and resets the option for waking r not waking to enabled).
I think it resets/arms itself always again the moment I send the PC back into standby. If I disable it, and put my pc to sleep, it is always on again when I wake it.
I tried to help.
Sorry I wasted your time.
I'll remove the useless post.
Try what is in the picture.
If this is useless also, tell me & I'll delete this post also.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Any progress ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
dfgfgd
50
Of course I didnt press the "start" button myself... And it didnt change anything, today at 7:40am (dont even know why that time where it was set to 3am) it turned on again, and when I looked into control center, "allow scheduled..." was enabled, AGAIN. What can I do about it?? It always enables itself again, again and again and again.
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
#8
Hi there. If UEFI BIOS, check to make sure settings are correct there.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
dfgfgd
50
#9
It's a Z77 board so it's UEFI, and system time is correct. Also all power wake options are set to disabled, even tried setting the option "event wake timers..." from disabled to "controlled by os", doesnt matter, it's like totally ignored, if set to off or os controlled. But that's irrelevant, I also want some to work like WOL, or specific events, but not this stupid Windows Maintenance. Disabling it completely also doesnt work. It always overwrites the settings after some time, to enabled AND to allow reactivate PC.
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
#10
I can see you're frustrated and I don't want or mean to frustrate you further. Just to let you know I'm not the savviest one around here. I know and am running an older Acer with legacy BIOS. I do not know much of UEFI other than it's a more sophisticated BIOS with far more options including storing OS keys there.
Just to make sure you have update KB2919394 installed because for some reason it's optional. That's the sleep fix update if you didn't know that already.
I have a good friend that will look at your problem closer, so hang in there.
I personally now think there is a correlation between UEFI and 8.1 by watching this huge thread: http://www.eightforums.com/general-support/28226-windows-8-1-refuses-sleep.html
A few questions: Did you run 8 prior to 8.1? If so, did you have sleep problems there? Are you saying that the OS does not change UEFI settings? Your real problem is that whatever changes you make get overwritten?
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
4wd
375
#11
I don't have this problem, and don't know much about it, but maybe take another look in Computer Management, Task Scheduler > Windows > Task Scheduler, the 'wake the computer' occurs in several places, are all unticked ? And maybe just disable maintenance (or remove the trigger), and run it manually now and then. Good luck.
    W8.1, W7
    HP \ Toshiba \ Lenovo \ Dell E7440
    FF
