Solved Refurbished HP Pavilion 17 Overheating/fan issue
SharpHD
Hi all. I recently bought this HP Pavilion 17 refurbished by the Geek Squad at best buy. the laptop is nice except for the processor. its a AMD A8-4500M, and it either is overheating, or the fan is just overkill. all i have to do s open chrome, and the fan gets audibly annoying. im not one to get annoyed by fans since my desktop is always on, but the laptop is LOUDER than all the fans on my desktop. CPUID HW Moniter says the CPU is running at 57 degress Celsius! :confused: thats not even a hot temp for this laptop. can someone help? free to give more info if needed.
    Windows 8.1/Windows 7
    Name
    Ian Stanley
    Dell XPS 630i
    Intel Core 2 Duo E8400 3.01 GHz
    Nvidia 650i SLI
    8GB DDR2
    Dual Nvidia 8800GT 512MB SLI
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    1x Samsung 840 SSD 120GB (Windws)
    1x 500GB Hitachi 7200RPM
    1x WD Caviar Blue 1TB 7200RPM
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Very old computer. Circa 2009
    Very trusty, no hardware issues.
    Saving up for parts for a Self-Built PC.
    Country Flag
    USA
CountMike
Check BIOS for fan settings.
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
SharpHD
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
SharpHD
The only thing i found was that there was a option for "Fan Always On" and turned that off. The fan still is always on and loud. Maybe i just need to accept that it has a loud fan or....?
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
SharpHD
i feel it might be overheating. dont know much about taking it apart, but im worried because even in chrome the fan is spewing out hot air.
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
CountMike
GS refurbished it ? Ugh. They may forgot or did not apply properly paste between processor and cooler. Is that temperature measured under load or at idle ?
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
SharpHD
45-57 idle. I'm not sure if hardware monitor is wrong though, because other programs say otherwise.
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
CountMike
Too high for idle, should not be over 10c higher than room temp. On the other hand AMD processors do not show accurate temps at idle. CPid Monitor should show max temperature too. Is that per core temperature you are measuring.?
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
SharpHD
Nope. Is there another program that would be more reliable, or does it not even matter?
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
CountMike
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
SharpHD
Thanks. I'll compare and see which ones show the same temps.
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
CountMike
You can also use Download to load up computer and watch temperatures and fan speeds at same time.
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
SharpHD
Alright i used some of those programs, and found while running chrome, it sits at 42-45 C. is this normal?
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
CountMike
That's tolerable, just Chrome or something on youtube? Try on youtube some flash video, it engages GPU which is in the same chip as your processor so it would work harder. Trick is to find max temperature and moment when fan speeds up.
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
SharpHD
Youtube makes it go to about 46-48C. I also found recording the screen using OBS, Makes it go to 56C.
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
CountMike
That's still very tolerable.
    Name
    Mike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Occupation
    Retired
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Country Flag
    Serbia
    State/Region Flag
    ca ontario
loveandpower
Yeah normally a laptop won't shut off from over heating until the 70/80's generally speaking.
You could always open her up, take the fan out ( careful really small screws!) get a thing of can air and clean the fan blades. Put the fan back in and try again. Are you physically able to feel the air from the fan hitting your fingers?
    windows 8.1
    Name
    Allison Brown
    iBUYPOWER
    AMD 8320
    Radeon 7850
    1024x768
    Occupation
    Administrative Clerk
    Azza Solaris
    50MBps download/10MBps upload
    Chrome/Firefox/Internet Explorer
    Malwarebytes PRO
    Country Flag
    USA
    State/Region Flag
    us georgia
SharpHD
Barely. It's loud, but not a lot of air is coming out.
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
SharpHD
Garry's Mod: 56C, Converting a 2GB video: 59C, when I am converting a video I can definitely feel the air coming out.
    Name
    Ian Stanley
    Dell XPS 630i
    Nvidia 650i SLI
    8GB DDR2
    SoundBlaster X-Fi
    22' Dell Moniter
    1680x1050
    Dell 750 Watt
    Occupation
    NOPE
    XPS 630
    Stock
    Razer Deathstalker
    AULA Ghost Shark
    30 Mega Bits
    Avast Antivirus
    Country Flag
    USA
loveandpower
As much as you may not like it then that may be your next step. Generally what you and I just discussed are good signs of either
A) a defective fan
B) a really dirty fan/inside of your case
    windows 8.1
    Name
    Allison Brown
    iBUYPOWER
    AMD 8320
    Radeon 7850
    1024x768
    Occupation
    Azza Solaris
    Malwarebytes PRO
    Country Flag
    USA
    State/Region Flag
    us georgia
