Reformatting Write Protected Flash Drive
Dawter
4
I have an 8GB flash drive that's write protected. There is no lock/unlock on the flash drive. How can I reformat/erase the contents so I can use the flash drive for other things?
I've tried low level and that didn't work.
Thank you.
topgundcp
San Jose - California
2,847
How did you get a flash drive write protected in the first place ?
Anyway, try this to see if it works:
Open an elevated command prompt then use the followings:
  1. diskpart
  2. list disk
  3. select disk n =============> n is the number of your flash drive
  4. attributes clear readonly
  5. exit
This should remove the write protected and hopefully you can format it.
Good luck !!!
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Dawter
4
Thank you. After "list disk" there are 4 numbers. How do I find the number of the flash drive?
I see the GB's amounts of my OS and external hard drive but don't see one with 8 GB (which is the flash drive.)
Admin Command
See Picture ---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
topgundcp
2,847
Did you plug it in the USB port before you run diskpart ? What was the format of the flash drive before ? was it Fat32 or NTFS ? Do you see it in the Disk Management ? You might have done some damage when you try to low level format it.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
asus
87
hi
With this freeware , you can not format flash memory that they will not transfer information to fix it
Did
100% tested .
    Windows 8.1 Pro 64 Bit
    Asus-IBM
    Intel core i7
    Asus
    4G
    Nvidia Gforce 610 m 2G
    Intel Graphic 3000 HD
