Reduce Indexing
falven
Hello,
I noticed that the indexing service on my computer is eating away at my battery. Every time I log in it begins rebuilding or checking whether items are indexed. Yes, I have let it run all the way until it stops. I have done it every time logged in.
So my question is, is there a way, besides completely turning it off, to just reduce the amount of times it runs, maybe re-schedule it to run once a week or something?
-Falven
    Windows 8 Consumer Preview 8250
David Bailey
Banned
Harrisonburg, Va.
Uncheck it & click apply & ok>>>
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
David Bailey
Banned
Harrisonburg, Va.
It should do the whole drive.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
broe23
Retired from the grind
Central IL
I have found that Windows Search still will set default directories, due to the File History program tells it those default directories. I have tried myself going in and unchecking them. Then around five boots later, they come back, due to File History.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
falven
I don't think you understand what I am saying lol
I'm saying I don't want to turn it off entirely. You can do that in the advanced settings, I just want it to run less often.
Wullail
Active Member
You can't , your only options are to disable it totally or reduce the locations that it indexes , there is currently no way to reduce how often it indexes.
As far as I know , it checks the set locations for changes and then re-indexes it if it finds any changed file timestamps or new files.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
