Recycle bin attached to External drive?
mike6623
149
Whenever I go to empty my recycle bin, my external seagate spins up. I looked at the properties and the drive is there listed as primary. I change it to "C" and it eventually defaults back to the external. why is this happening and how can I fix it permanently
    Windows 8 Pro
    HP Pavilion Elite
    16GB
LMiller7
Active Member
704
Normal behavior.
There is a $Recycle.Bin folder on each drive attached to the computer which contains files deleted on that drive. When you empty the recycle bin the OS must check the $Recycle.Bin folder on each drive to see if it contains any entries that need to be deleted.
Unless I have misunderstood your question.
    Windows 7
