Solved Recovery Drive Not Recognizing Flash Drive
10
Recovery drive won't allow me to use my 8 gb flash drive. It doesn't even recognize it. It will only recognize it when i uncheck the "Copy the recovery partition from the PC to the recovery drive. I'm assuming this is because unchecked needs 512mb and checked needs 8gb, but like I said I am using an 8gb flashdrive. Could it be because the full 8gb isn't available on the drive (only 7.45 gb is allocated) If so, can I make my flashdrive use its full 8gb? I've posted pictures below just in case you need more of an idea about what I'm talking about.
Ztruker
You need a larger drive.
Now I'm Outta Here answered 9 months ago: My 8gb usb only shows as 7.45 gb? - Yahoo Answers
that's the way it works
true 8GB will be equal to 8,589,934,592 bytes
- that number comes from 1,024 x 1,024 x 1,024 x 8
but the storage industry decided to start ripping us off along time ago and changed the 1,024 down to 1,000
thus the new formula is 1,000 x 1,000 x 1,000 x 8 = 8,000,000,000 bytes
which after windows converts back to real GB you get aprox. 7.45GB
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
10
Thanks for the quick reply. Can the 512mb option restore my computer to the way it was when I first bought it or do I need the full 8gb to do that?
Ztruker
Not a chance, you definitely need to copy the recovery partition to the flash drive.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
Ztruker
I used a 16GB flash drive (shows as 14.9GB) and it only has 2.71GB free, so it takes a bit over 12GB to create it for my Lenovo IdeaCenter K450.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
theog
Gold Member
5,591
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
genet
879
#8
You don't need USB flash drive, if you want to refresh/reset Windows 8 (see the instructions below). But I would recommend you first create a recovery USB flash drive, if Windows 8 won't start correctly.
http://www.eightforums.com/tutorials/2269-system-recovery-options-boot-windows-8-a.html
To Open "Recovery" Options in PC settings
1. Open PC settings, and do step 2 or 3 below for the Windows 8 you have installed.
2. If you have Windows 8 or Windows RT, then click/tap on General on the left side, and go to step 4 below. (see screenshot below)
3. If you have Windows 8.1 or Windows RT 8.1, then click/tap on Update & recovery on the left side. (see screenshot below)
A) On the left side, click/tap on Recovery, and go to step 4 below. (see screenshot below)​
4. On the right side, click/tap on the recovery option that you would like to do. (see screenshots below step 2 and 3A)
Refresh your PC (Refresh your PC without affecting your files)
Reset your PC (Remove everything and reinstall Windows)
Advanced startup
    Windows 10
    Lenovo G580
    Intel Core i5-3230M
    8 GB
    Intel HD Graphics 4000
    Microsoft Edge
    Windows Defender, standard user account
    UEFI firmware (BIOS) embedded Windows 8 product key.
caperjack
Just the Janitor
2,627
#9
Advanced startup
that good if the computer is working ,booting to windows
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
theog
Gold Member
5,591
#10
& installed with Windows 8.1, not the UPDATE.
    Notebooks x 3
    Desktops x 5
    Towers x 4
