Solved Proper Shutdown? hold "Shift"
884
Hi,
I've just read about Holding "Shift" while pressing Shutdown in windows 8.1
What is the difference when I do, and do not hold shift with shutdown?
and why would I ever want to not "fully" shutdown with shift pressed?
thanks.
    windows 8.1
    Lenovo g750
    i5
    Some Chinese Crap..
    Nvidia 755
Atomcrusher
    Windows 8.1 Pro 64-bit
    ASUS X54C
    Intel Pentium B940 2.00GHz Sandy Bridge 32nm Technology
    OEM - ASUSTeK Computer Inc. Model K54C (CPU 1) Version 1.0 Chipset Vendor Intel Chipset Model
    6.00GB Dual-Channel DDR3 @ 665MHz
    OEM - Intel Model HD Graphics
    OEM
    OEM
    Manufacturer Hitachi
    Product Family Travelstar
    Series Prefix Standard
    Model Capacity For This Specific Drive 500GB
    OEM
    OEM
    OEM
    OEM
    4 Mbps ADSL
    Chrome 64bit
    Billion 400G Wi-fi router
884
Hi,
very good info AtomCrusher,
now does this mean my hiberboot is disabled? I do not see the "fast boot" in my control power settings .. and i looked at this in the registry..
    windows 8.1
    Lenovo g750
    i5
    Some Chinese Crap..
    Nvidia 755
Phone Man
Retired Bell Head
Covington, La
1,177
Select Power Options and then on the left side select "Choose What the Power buttons Do" and the next screen has the Fast Startup option.
Jim :cool:
    ASUS - Home Built
    AMD Phenom II X6 1100T
    ASUS M5A99X EVO
    MSI R6850 Cyclone IGD5 PE
    On Chip
    Corsair 400R
    AVS Gear Blue LED Backlight
    15MB
    NIS, Malwarebytes Premium 2
    Epson V300 Scanner
884
Yes, mine is not listed there so I must have it disabled.. which, I want it disabled so It appears all is correct
    windows 8.1
    Lenovo g750
    i5
    Some Chinese Crap..
    Nvidia 755
