Solved Programs and features ,Only 8 programs installed
sparkie415
54
Hi, I hope someone can help. i went to uninstall a program via programs and features and noticed that the list and icons only showed 8 programs installed ,i'm certain there is normally around 70-80.
Everything appears to function as before so i assume the programmes are there hidden somewhere and not uninstalled.
Has anyone come across this before?. i'm running windows 8.1 32 Bit.
Regards Dom
    windows 8 pro
MilesAhead
Eclectician
2,130
Just for grins I would suggest getting MyUninstaller freeware. See if it shows the same.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
rfruth
Houston, Tx
88
Not run into that myself (BUT if the program was installed from the Microsoft store ((start screen)) it may not show in Programs & Features)
    Win 8.1
    HP Envy 700z
    AMD 4.1 GHz quad-core
    MSI
    8 GB
    Integrated Radeon HD 8670D
    Integrated Sound, Envy Audio; Beats Audio
    1TB 7200 RPM SATA
    460 watt
    wired USB
    wired USB
    IE11 / Chrome
    Windows Defender aka MSE
alphanumeric
slightly off center
Gold Member
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
