Problems with the APPS section
jeffrys
hi guys,
Must i place this in the Graphics section, the Drivers section, do not know, so here it is.
Recently and finally i changed my monitor to HDMI (bad idea).
After some problems Windows installed the Intel 4000 driver for the monitor.
Now i have too large tekst when going into the apps section. Even hitting the right corner then the tekst and icons are too big on the Charms Bar.
thanks
Jeff
    WINDOWS 8.1 x64
    INTEL CORE I--3770K LGA1155
    ASUS P8Z77-V
    KINGSTON 2400 MHZ KHX24C11K4 16GB
    INTEL HD GRAFICS 4000
    Philip BDL3245€ 32 inch
    2 SAMSUNG 840 PRO RAID 0 ON BOARD 2 x 128 GB
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
JustATest
Expelled
Is that the only view that looks that way? If not, any chance you have something set for dual monitors? BTW, your apps view looks more like my 8.1 view than my 8.0 view.
    Windows 8 Pro Windows 8.1 Preview
jeffrys
no JustATest,
all of a sudden the apps start on the left side instead in the middle.
They are really too big, not as you see on the printscreen.
no dual monitor and i am on Win 8.1, forgot to mention that.
Include a second prtscrn, from the Charms Bar, maybe that gives you an idea, if not i deleted this one.
thanks
Jeff
if you look at the left side what was typed and you see the Charms Bar on the right, that is a big difference.
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
JustATest
Expelled
Hi Jeff,
I thought you might be on 8.1 but I am sorry that I am totally confused about what your real issue is now. You originally show a screen where the apps are skewed to the right. You then report they start on the left side instead of the middle. You also claim they are too big and I don't see that. Sorry but I'm just not understanding your issue so if you think you have clearly stated your issue, then maybe its just me.
jeffrys
well i admit it is difficult to see.
But the APPS section is really to big, so is the Charms bar.
i can resolve that if i go back to a VGA connection.
But thanks
Jeff
PS
yes, one time it was more to the right while the bar under was on the left. That is solved, not by me though.
One can make the text smaller but not in the APPS section and that is strange.
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
JustATest
Expelled
OK, thanks for that explanation. Now that did ring a bell for me! By chance, are you using a combo PC/TV monitor? If so, that would explain why you are getting different sizes via different connection methods. Specifically, if you do not have a PC only monitor, and you try to use a PC/TV combo monitor with an HDMI connection, your screen will actually look like a TV using HDMI. However, when you use a dedicated VGA connection, that is specifically designed for a PC connection, that could be the difference. Did I get it?
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
jeffrys
thanks Brink,
did not try this, but found this:
hit the Charms Bar, change pc settings, pc & devices, display, then more options, smaller and yes back to normal.
but thanks for your info.
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
Great news Jeff. Yep, that was OPTION TWO. :)
    Lumia 1520 phone
XweAponX
I use Nvidia and the Geforce software has a setting for "Resizing the Screen" - Intel Chipsets have a setting for "Change Scaling" which is the same thing. Because most HDMI will extend beyond the extant of the screen at 1920 by 1080p. You you have to scale back the screen size a little with custom scaling.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
jeffrys
welll Brink, i know one can count on you.
Thanks
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
XweAponX
Shawn is da man. Every time I install a Geforce Driver update, it sets my screen to full 1920 by 1080, the actual size has to be scaled down to 1850 by 1035 or so, or else my taskbar can't be seen
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
jeffrys
hi guys,
Well although one can make the text smaller in the APPS section as mentionned above, after a reboot one has to change this AGAIN.
Is there a way to change the DEFAULT setting in SMALLER permanent.
thanks
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
Hey Jeff,
Odd, the setting should not reset like that. The smaller "Default" option is the default setting. This is a per user setting, so is this the same account that you had it set for this?
    Lumia 1520 phone
XweAponX
That's why I asked if he were in some kind of Temporary Profile.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
hi guys,
thanks
Jeff
Did you click the Apply button after setting to Smaller ?
A picture:
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
hi guys,
thanks
Jeff
A picture:
Hello David,
Sorry, but that would only apply for the desktop DPI. It has no affect on the modern UI (metro) screens DPI.
http://www.eightforums.com/tutorials/28310-dpi-scaling-size-change-displays-windows-8-1-a.html
    Lumia 1520 phone
OK.
I thought he was using Desktop.
My mistake. :(
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
No worries mate. :)
    Lumia 1520 phone
jeffrys
no David, when doing it as mentionned above, i have the default, then i change it to smaller, there is no apply for it.
BUT not only do i have this when rebooting, but also when coming out of the lockscreen this morning it went to "DEFAULT".
This is strange, was not like that yesterday.......
However, let's call this a but in the beta version.
Jeff
    WINDOWS 8.1 x64
    ASUS P8Z77-V
    LOGITEC MX™ 5500
    LOGITEC MX 5500
    120 Mbps
