Problem
bagavan
Why do I get this even though I have intel products?
    Windows 8.1 professional x64 + WMC
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
That is the intel driver utility update tool. By the looks of it you are using the windows 8 beta drivers before windows 8 was released to the public.
Did your laptop come with windows 7 and you upgraded to windows 8? This would explain the beta drivers. Does your laptop support the windows 8 OS?
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
HippsieGypsie
It's Gururrrrrr8!
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
bobkn
Can my acer aspire 5750g work with windows 8? Help!
(This must be the quickest thread hijacking I've ever seen. You should have posted in a new thread.)
As support.acer.com has Windows 8 drivers for the 5750g, yes.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
bagavan
It had windows 7 and I upgraded to windows 8. I purchased an upgrade copy in November end and I upgraded to it
I am not using any beta drivers.
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
bobkn
So, you are already running Windows 8.
Are you having some sort of problem with it?
If you did an upgrade-in-place to Windows 8, you might have done better to do a clean install.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Silverstone FT02B-W
    6Mb cable
bagavan
I had done a clean install.
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
bobkn
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Silverstone FT02B-W
    6Mb cable
Skulblaka
Are you Alive?
Have you checked the "optional updates" (or updates in general) in Windows Update? Perhaps there are more recent (or compatible) drivers available.
    Windows 8.1 Professional 64-bit
    Custom
    Intel Core i5-3570k
    ASRock Intel Z77 Extreme4
    8GB
    NVIDIA GeForce GTX 670
    Hyper 212
bagavan
Yep.I have checked.
I have no other problems
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
Skulblaka
Are you Alive?
Have you done a web-based search for your drivers? I don't like those update "managers" (bloatware). Perhaps you simply need to update your drivers. In your screenshot I see that there's a "Download Center" button, click that and see what happens. Perhaps there's a list of drivers you can update.
I have done some searching. Here's the page for the Audio Drivers and here's the page for your Chipset. Your Chipset hasn't been updated for Windows 8, so the latest supported OS is Windows 7. Sometimes the drivers work fine, although I cannot say for certain.
    Custom
    Intel Core i5-3570k
    8GB
    Hyper 212
bagavan
Thanks for spending your time
I already have the latest drivers and I have directly downloaded and installed them. My question is that why is intel utility not recognizing the drivers?
    Acer Aspire 5920
    Core 2 duo T5550
    ACER CHAPALA
    4GB DDR2
    Intel GMA X3100
    1280 X 800
    160 GB HDD
