Problem with svchost
Avalon
Away for a bit
Australia
584
So uh... I'm using my computer for many hours... and finally notice that I am using 4GB of RAM... on idle.
Everything seems to be running as normal... Any ideas at what this could be?
Edit: I tried to create a dump but it was taking too long, so I cancelled it, and noticed that the same process increased by 300MB, and now Task Manager will not respond.
I have not installed anything recently, have been running everything as normal.
Update: The memory started leaking even further, to the point where explorer.exe became unresponsive, task manager became unresponsive, even command line wasn't working. I had to force a shutdown.
Windows then decided that my Windows 7 partition was active again, and decided to show it in the boot list. That was after taking a minute to get past the initial boot screen (it's usually about 5 seconds).
The preview of the desktop in my Start Screen is also rather borked now.
    Windows 8 Dev Preview x64
    i7 950 3.06GHz
    Asus Rampage III
    G Skill 4GB DDR3 2000MHz
    Nvidia GTX570 1.25GB DDR5
    Antec ATX TruePower 750W
    Antec Lanboy Air Red
Capt.Jack Sparrow
BSOD Kernel Dump Analyst
Hello there!
svchost.exe is actually a bundle of services. You could download Process Explorer and see what is running underneath svchost and suspend each one to identify which one is leaking.
    Windows 7
Avalon
Away for a bit
Australia
584
Hello there!
Thanks, I will download it and keep it for when it happens again. :)
    i7 950 3.06GHz
    Asus Rampage III
