Problem with scrolling
Mirac7
146
Not sure if this is the right category...
Anyway, when playing some games like c&c i can't scroll to the left.
can i set my computer to automatically remove ability to 'take' other apps running in background when playing games?
it really annoys me that i can't scroll to the left.
if not possible, can i permanently remove it, cuz i really don't use that feature.
i rather use keyboard...
    attempting to run Windows Consumer Preview
    Intel Pentium dual-core E6700 @ 3.20 GHz
    Gigabyte G41MT-D3V
    4,00 GB
    Acer A221HQL
    Primary Seagate Baracuda 7200, 1000GB
    External: WD 2000GB, WD 8000GB, HP 16000GB
Hopachi
Polyhedric Stellation
Orbiting the Moon
2,975
You mean the metro style apps that go fullscreen when used?
For c&c you need to scroll to all four sides of screen. But yeah, with metro enabled we have a problem.
The apps in background are in as suspended state (still in ram) but don't actually run when in background.
Does it work if you disable metro? It's just a temporary solution for older (non-metro) programs . After I disabled metro, I couldn't run the metro apps anymore but scrolling works to the left in older programs.
I don't know what the solution would be in the final release (maybe something in Control Panel to customize Metro look and feel).
Cheers
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
Mirac7
146
When I first ran the game, it was poor resolution, and couldn't set 1920 1080 (native) in settings so I edited options.ini file. When working on a resolution set in the game it works fine. It's just the problem that it won't work in 16:9...
    Gigabyte G41MT-D3V
    4,00 GB
    Acer A221HQL
Hopachi
Orbiting the Moon
2,975
Which c&c you use, the old c&c95? (you will need some hacks for this one to get higher resolutions but no hd Command and Conquer HiRes Patch - Game Download)
I didn't tested with that one. I know that in Red Alert 2 and Yuri's Revenge and maybe in Tiberian Sun you can insert custom resolution in the options.ini (works also in 16:9 but the menu's when paused show the 4:3 design).
So I got RA2 working in 16:9 (1366x768 and 1360x768 => I don't have HD monitor but should work).
Good luck
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Mirac7
146
i've changed option.ini in c&c generals. now im just running on highest possible by game. i think its 16:10 or something like that...
    Gigabyte G41MT-D3V
    4,00 GB
    Acer A221HQL
Hopachi
Orbiting the Moon
2,975
Good to know it works.
Generals (and Zero Hour) seems to be buggy sometimes. You only have 4:3 resolutions ingame and it stretches to what you need 16:10 ofr 16:9
There is a good mod on Generals Zero Hour called Shockwave. (C&C: ShockWave mod for C&C Generals: Zero Hour - Mod DB) They've made the game Windows 7 compatible but I didn't tested (if there are) some extra game resolutions.
Thanks
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Mirac7
146
maximum ingame rezolution is 1400x1050 on 1920x1080 screen. And that's ok. As long as it ain't something like 800x600... :)
    Gigabyte G41MT-D3V
    4,00 GB
    Acer A221HQL
