Problem with Product key on Laptop?
Dragu
Hello,
To start things off I recently purchased a Lenovo Y500 and just can't stand the pre-installed programs and setup.
The problem is there's no product key on the back of the laptop, or in the manuals I got with it.
People suggested me using a keyfinder to get my Product key, but a lot of people say that the product key used is a manufacturer key which is useless when installing a fresh version of windows.
Does anybody know if I'ld have to purchase another product key or if using a keyfinder would actually work?
Thanks for helping!
    Windows 8 64-Bit
    Lenovo Y500
Tews
Team Member
    64-bit Windows 8.1 Pro
    Asus CM5675
    IntelCore i5 3.20Ghz
    Asus CM5675
    6.0Gb
    Intel HD integtrated
    SB Audigy
    Samsung 24'
    1900x1080
    Segate 1tb
    Intel 120Gb SSD
    100mb down /10mb up
Dragu
If you're going to install anything other than what came with your laptop, you will need to purchase a new key. If you plan on re-installing the factory image, you can recover the key with Belarc...
Belarc Advisor - Free Personal PC Audit, for software, hardware and security configuration information on your computer. Software license management, IT asset management, cyber security audits, and more.
My laptop came with windows 8 and a bunch of programms nobody uses pre installed.
So if I recover the key it will work when installing windows 8 again, or did I missunderstand that?
    Windows 8 64-Bit
    Lenovo Y500
Tews
Team Member
    Asus CM5675
    Asus CM5675
    6.0Gb
    SB Audigy
    Samsung 24'
    1900x1080
    Segate 1tb
    Intel 120Gb SSD
    100mb down /10mb up
Phone Man
Retired Bell Head
The key should be embedded in the Bios and if you install the same version of Windows then it should read the key and activate. If you install a different version then you need a new key.
Jim :cool:
    Name
    Jim
    ASUS - Home Built
    AMD Phenom II X6 1100T
    ASUS M5A99X EVO
    MSI R6850 Cyclone IGD5 PE
    On Chip
    Occupation
    Retired
    Corsair 400R
    AVS Gear Blue LED Backlight
    15MB
    NIS, Malwarebytes Premium 2
    Epson V300 Scanner
    Country Flag
    USA
    State/Region Flag
    us louisiana
robinb9
I am Woman! Hear Me Roar!
what i do not understand is how you could buy a laptop and not get the product key? it normally is on the underneath part of the laptop. Go back to where you bought it and demand the key.
    4 Windows 7 Pro Sp1- 4 Win 8 Pro, 1- xp pro sp3
    Name
    Robin
    Dell Optiplex 390, 380, 3 Vostro Laptops (7 computers in all)
    desktop/laptop
    4gigs
    atm randioum
    Occupation
    IT
    Country Flag
    USA
    State/Region Flag
    us new jersey
Dragu
I bought it from amazon so I don't really know where to demand my key...
    Windows 8 64-Bit
    Lenovo Y500
Tews
Team Member
Did you run Decrapifier? What were the results?
    Asus CM5675
    Asus CM5675
    6.0Gb
    SB Audigy
    Samsung 24'
    1900x1080
    Segate 1tb
    Intel 120Gb SSD
    100mb down /10mb up
DavidY
Active Member
I don't think this is true on PCs with Windows 8 pre-installed by the OEM. The key is baked into the BIOS so there's no need for a sticker as you should never need to type it in.
    Windows 8.1, 10
Phone Man
Retired Bell Head
:ditto:
Jim :cool:
    Name
    Jim
    ASUS - Home Built
    ASUS M5A99X EVO
    On Chip
    Occupation
    Retired
    Corsair 400R
    15MB
    Epson V300 Scanner
    Country Flag
    USA
    State/Region Flag
    us louisiana
    Name
    David A. Bailey
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Occupation
    Trying to live a good life before I die.
    Opera 24.0
    Avast Internet Security
    Country Flag
    USA
    State/Region Flag
    us virginia
alphanumeric
slightly off center
Gold Member
You don't need to know the product key on OEM PC's with Windows 8 preinstalled. The product key is embedded in the BIOS and any official Windows 8 install media will read it automatically. The tricky part is getting the install media. I did a clean install of Windows 8 on my ASUS laptop and the product key was auto detected and the matching version, 8 core was installed. Activated online no problem. It shipped with 8 core preinstalled and that is what the product code is good for. There is no COA sticker as its not required.
    Windows 10 Education 64 Bit
    Name
    Kerry Waterfield
    Asus
    Thermaltake TR 620
    Occupation
    Retired
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
    Country Flag
    Canada
    State/Region Flag
    ca novia scotia
NiFu
Run this vbs script to get your Product ID & Product Key:
If you have installed "Windows 8 Pro with Media Center" then your script shows the "Windows 8 Pro with Media Center" key - right. But with "Windows 8 pro with Media Center" key you can not install "Windows 8 Pro". And normal, unmodified ISOs doesn't include "Windows 8 Pro with Media Center" - only "Windows 8" and "Windows 8 Pro".
    Country Flag
    Germany
    State/Region Flag
    de bavaria
alphanumeric
slightly off center
Gold Member
Yes, that script shows the Product Key that the PC is currently activated with. In my case it shows my Media Center key. And yes, you can't install 8 Pro with Media Center from official install media. Only 8 core and 8 Pro are supported. Your Media Center key will be refused. You have to enter an 8 core or 8 Pro key. In my case 8 core is installed by default because of my embedded key. I don't get an option to enter a key. I then upgrade to Pro though "Add Features", and then do it again to get to 8 Pro with Media Center. As I mentioned earlier, if your PC has an embedded code there is no need to run that script. Not unless you have upgraded and forgotten the code used to do it.
    Name
    Kerry Waterfield
    Asus
    Thermaltake TR 620
    Occupation
    Retired
    Stock heatsink fan
    Country Flag
    Canada
    State/Region Flag
    ca novia scotia
NoelDP
Three-Toed Sloth
Windows 8 does NOT have a product Key on the laptop, as it's stored in the BIOS along with the SLIC table. The OS reads both, and activates accordingly.
    Win7 64-bit and Win8 32-bit in VM (+ others in VM)
    Name
    Noel Paton
    Asus K52F
    i3
    8GB
    it's an i3 :)
    Conexant (rubbish - or it may be the speakers)
    1366x768
    Occupation
    Chance would be a fine thing!
    whatever I can get - G3
    Country Flag
    UK
    State/Region Flag
    uk wales
