Problem with Laptop automatically coming on every-night?
Tarka Dal
We have had this Laptop Samsung NP355V5C-A06UK for 15 months and it has been switching on at 23:49 every-night for months since we had it repaired at Samsung9 months ago. At first I tried everything I could think of by changing event times and looking at what was waking it up. I found nothing to answer my question?. Then I tried the BIOS to see if that was the problem as usual no success. The other night I switched off the WIFI to see what happens. You guessed it, it didn't come on?
So, what does this mean does someone have access to the laptop?
How did they know my IP and Mac#?
How the hell can I stop them from using it?
Thanks guys for your info...
TarkaDal
    Win8 pro
    Computer 1 of 4
    ASUS M4A78LT-M LE
    4GB Kit (2x2GB)
    Samsung 18"
    1080p
    Cheapo
    30mb
    Computer 2 :~ Dell Inspiron - 1x 350gb & 1x 250gb - 6GB Memory - Win 7 | Computer 3 :~ Samsung 355v5C Notebook - 6Gb Mem - Win8 2Core| Computer 4:~ Samsung 355v5C Notebook - 6Gb Mem - Win8 4Core
MilesAhead
Eclectician
If you have it networked to your other machines it may just be something like Windows testing if offline files have changed. Or discovering what systems are on the network. Try turning on one of the Desktops "allow network activity to wake" it setting in the network card in Device Manager. See if it wakes up at the same time.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
Tarka Dal
As you can see from the pic below:~
It is switched off so the laptop should not wake. Yes?
    Win8 pro
    Computer 1 of 4
    ASUS M4A78LT-M LE
    4GB Kit (2x2GB)
    Samsung 18"
    1080p
    Cheapo
    30mb
alphanumeric
slightly off center
Gold Member
Check the BIOS for a "WAKE on RTC" setting. If enabled the PC will turn on every day when the BIOS Real Time Clock time matches what's set in this BIOS setting. I used to have my desktop PC set to turn on every morning at 7 AM.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
MilesAhead
Eclectician
Learn something every day. :) I'd rep you but I got the "spread around" msg. :) Nice info.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
Tarka Dal
I have UEFI Bios where would I find it?
    Win8 pro
    Computer 1 of 4
    ASUS M4A78LT-M LE
    4GB Kit (2x2GB)
    Samsung 18"
    1080p
    Cheapo
    30mb
MasterChief
Banned
In addition: Taskschd.msc
Rid of Customer Experience Improvement Program and Office stuff.
Check triggers about other things.
    7601.18247.x86fre.win7sp1
    Self-built Intel based
    Intel DQ965MT
    Hyundai 2 GB DDR2 @ 333 MHz
    Thermaltake 450W
    Logitech M510
    Optimum Online, fast for US
    Pale Moon
alphanumeric
slightly off center
Gold Member
Likely in the power options. It should be in the same place as the Wake on Lan etc settings.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Tarka Dal
    Win8 pro
    Computer 1 of 4
    ASUS M4A78LT-M LE
    4GB Kit (2x2GB)
    Samsung 18"
    1080p
    Cheapo
    30mb
alphanumeric
slightly off center
Gold Member
My two desktop PC's have the Power section but my laptop doesn't. It appears my laptop doesn't have the Wake on RTC option. Your may not also.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
