Problem with backup system image
Lorenzo Farina
Hi to all
i have this problem when i try to create a backup image system, i find volume E (hdd internal) read like system.
The volume E it's a partition of internal hdd.
Thanks
What is on E:\ ??
from cmd prompt(admin)
diskpart
list disk
select disk # (# being the disk number containing E;\)
list partition
select partition # (# being the partition number containing E;\)
detail partition
post pic of cmd windows
and the partition attributes show it as a primary partition..
BUT you are selecting Detail partition 2
Follow the Directions ABOVE exactly
and post pic
Also post pic of Disk management
Must i select partition 1 ?
Partition 2 it's E partition
Details partition 1 bellow
Partition 1 it's hide and not "request"
diskpart
select disk 1
select partition 1
set id=EBD0A0A2-B9E5-4433-87C0-68B6B72699C7
That partition has the attributes of a reserve partition - need to change the attributes to a primary partition (as above)
Error by service virtual disks
The operation is not supported by object.
The command or parameters specified aren't supported in the system in use.
Kind of figured that would be the case....
Because you can not change the ID on a reserve partition....
You would have to Delete the partition and re-create it...
Yes i reboot
If i format and reinstall all os and i format the disk that contain E partition can i solve the problem.
And i set other id of partition 2 (not 1) ?
Disk 0 is your OS drive ?? correct ??
Disk 1 and disk 2 are DATA drives ??? Or what ??
