My CPU cooler, an Antec Khuler H2O 920, is powered by internal USB 2.0. This allows the radiator and fans to be controlled from a program inside Windows (ChillControl). The fans and radiator pump work, but I am unable to get the fans to run any faster than idle (this is important for doing anything that significantly uses the cpu). Normally controlled by the ChillControl utility, I get this error when the utility starts:
Here is my speculation: I have an Asus P6-X58E-Pro motherboard, and Asus does not seem to have drivers for Windows 8 available. Because the cooler is powered and controlled by internal USB, and the error I get seems to be related, this may be a motherboard driver issue.
Based on that, I'm not really sure what to do. Thank you in advance for the help
The cooler is certainly connected because the hardware still works and was not changed at all when upgrading to Windows 8. I contacted Antec customer support about it, and they had no idea.Cannot connect to Chill Control device. Check USB connection on device and restart the Chill Control Application
