Problem with 8GadgetsPack - Multiple instances
vrosa
Tech Addict
Belo Horizonte, MG, Brazil
The software has been working fine for months, but now it freezes at startup with multiple instances of its Network Monitor II and System Monitor II gadgets. I have been trying to resolve that all day along, but nothing.
1st try: Uninstall >> Run CCleaner >> Reboot >> Reinstall :mad:
2nd try: Uninstall >> Run CCleaner >> Reboot >> Run CCleaner >> Reboot >> Reinstall :mad:
3rd try: System Restore >> Reboot >> Message: "System Restore could not be finished : Error" :mad:
4th try: Live without the software - OK :cry:
All tries to resolve the odd bug , except the 4th one, failed !!!
What file may be keeping the bad configuration data?
Thanks in advance.
:think:
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
5th try: Eliminate all reference traces to registry key {30B62757-D45D-48E8-BF43-8379330E61AB} and delete all hidden files inside installation folder - OK
It WORKED !
:dinesh:
:cool:
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
    Windows 8.1 Pro 64 Bit
    Home Built System
    Intel Core 2 Quad Q9450 2.66Ghz, Overclocked to 3.3Ghz
    Gigabyte GA-EX38-DS5
    8GB XMS2 4GB DDR2 PC2-8500
    Gigabyte 660GTX 2GB
    Samsung SMS27B970D
    1xSAMSUNG SSD 840 Pro Series Basic 2.5" - 512 GB - Boot drive
    2xSamsung Spinpoint F1 750GB
    Corsair 520HX
    Antec P182
    Zalman 9700NT
    12Mb/s
    I did a fresh format and install of Windows 8 64 Bit Pro. Sorry but I couldn't live without a start button so I have installed the Start8 start menu which is great. I try sometimes not to use it but find metro frustrating to find programs as I have many. I will use Metro for apps only and desktop of serious computing.
Hey, tonymarcus: many thanks for the heads-up on the new version. I use 8GadgetPack and the last version I saw was version 8.
No problems
    Home Built System
    Gigabyte 660GTX 2GB
    Samsung SMS27B970D
    Corsair 520HX
    Antec P182
    Zalman 9700NT
    12Mb/s
How are you getting on with version 10, mine is sometimes crashing at start up and recently my PC is freezing at the metro screen after booting, I think it might be version 10 causing this. Any problems on your machine?
Thanks
TOny
    Home Built System
    Gigabyte 660GTX 2GB
    Samsung SMS27B970D
    Corsair 520HX
    Antec P182
    Zalman 9700NT
    12Mb/s
