Problem while accessing a particular website
avidqtaqtx
Delhi
Hi guys
i am not able to open a particular site
the thing is that it shows 127.0.0.1 not available but i didn't entered this local host address
i even checked hosts file in C and it's not present there
also i use Proxycap a proxy filtering software to redirect all my incoming and outgoing connection through a proxy
and all websites opens except for this
    HP Pavilion G6-2302AX
    APU Dual Core A4 2.5 GHz with Turbo Core Technology Upto 3 GHz
    AMD
    6GB
    512 MB AMD Radeon HD 7420G (Integrated) and 1 GB ATI Mobility Radeon HD 7670M (Dedicated)
    HD Audio, Dolby Advanced Audio v2, Stereo Speakers
    HD Brightview Widescreen LED Backlit Display
    1366 x 768 Pixel
    1TB
    10MBps
    Chrome
Open an elevated command prompt and enter this command:
nslookup sitedomain
where site domain is the site you are trying to surf to. Don't put in the http://
also try it with and without the www if the url has the www included.
If it's a name service issue you should see it give the 127.0.0.1
If it gives other numbers try surfing to it using "http://" followed by the numbers returned by nslookup
(The double quote are just so it won't show as a link when posted. Omit them.)
where numbers ae copied and pasted from the nslookup info.
example:
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
nslookup sitedomain
example:
ok i did what you said
this is what i got
i tried to open through ip and got this error
[h=2]Direct IP access not allowed[/h][h=2]What happened?[/h]You've requested an IP address that is part of the CloudFlarenetwork.
    AMD
    6GB
    1366 x 768 Pixel
    1TB
    10MBps
    Chrome
It may be blocking your IP for some reason.
Try sending an email to
support@domain
It sounds like it's blocking. Somebody may have tried to DOS them from an address similar to yours or even spoofed your address. Only they can say what the issue is.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
