Solved Problem sharing PPPoE internet connection
bocovp
I have a problem sharing PPPoE internet connection after installing Win8 in top of Win7.
On my computer (say, "Computer A") I have 2 LAN ports on the motherboard:
1-st one ("Ethernet 1") is connected to internet provider
2-nd one ("Ethernet 2") is connected to "Computer B"
I am trying to set up internet an connection on "Computer A" and share it to "Computer B";
I created a broadband connection and checked the checkbox in its sharing tab, allowing other users of the network to be able to use my internet connection (I specified the "Ethernet 2" connection as the "home network connection" in this tab)
Then I configure the TCP/IP v4 protocol on the "Ethernet 2" connection in the following way:
IP 192.168.137.1
subnet mask 255.255.255.0
default gateway: 192.168.137.1 (but after closing and opening the protocol properties window this field became blank)
DNS 192.168.137.1
I tested both computers can be ping-ed from each other.
After this simple configuration I am connecting to the internet.
I have the internet on "Computer A", but NO internet on "Computer B".
Moreover, on computer B, while I am trying to ping some site, its IP addess is determined correctly, but sill no internet.
Can anyone help me, I killed several days trying to solve this problem. Once again I had no such problem on windows 7 with the same hardware
Computer A:
MB P5Q-E
Ethernet 1 adapter: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
Ethernet 2 adapter: Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller
Windows 8 Profesional
Computer B:
Samsung N150 Netbook
Windows XP
    Win8
Jarhead69
Have you tried RIGHT clicking on the network adapter, and selecting properties, and then clicking the sharing tab.
Tick "Allow other network users to connect through this computers internet connection."
    8 and 7
bocovp
Yes, i tried setting the "Allow other network users to connect through this computers internet connection." checbox on the broadband connection (in this case secon Computer B at least resolves internet addresses to IP).
I also tried ticking this checkbox on the "Ethernet 2" adapter
    Win8
chev65
Closed
Have you tried going into services.msc and change the "internet connection sharing" setting from disabled to Automatic. I would also set it up with Ethernet connection 1 as the Home Network.
Go to bottom of page in link for more information. :)
Internet Connection Sharing ( ICS ) not working in Windows 8 CP
I'll assume that my advice solved this problem "since it's marked as solved" as I have already solved this problem with the same fix many times already.
For some reason they disabled this setting by Default which did not use to be the case.
The gateway IP showing up as the DSN server is simply because the router is being used for the DNS which is the way to go in my book .
There is absolutely no reason to type DNS servers into the IPv4 properties if you already have DNS servers set up in the routers settings.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
kaybee327
Bocovp
Another suggestion for you (keep going ) :dinesh:
Just read your first post again and I would not be happy with the dns setting being the same as gateway. I checked my properties which are as shown and would suggest giving them a try obviously keeping your own IP numbers.
Another thing I not is that you have the same machine address as the gateway ---- that is a nono :mad: they need separate addresses maybe try 192.168.137.15
Apart from my IP numbers the settings are from my laptop which connects via Ethernet or WiFi so hopefully they would work on yours - fingers crossed. DNS numbers are public from Google or you could get them from your ISP.
Best wishes
Keith
    Win 8 64bt
    Asus Aspire
    Sempron 2.8
    Asrock
    4GB
    Intel
    Realtek
    Samsung
    1024 x 768
    2 x ide
    1 x sata
    Up to 24 :)
