Problem setting Classic Shell
Have just got my new Asus ROG G750JM and want it like my old Toshiba and downloaded Classic Shell to get rid of the awful 8 button but have ended up with the set up in the picture. (Adding the snip was an exercise in frustration too)
Anyone know of how I can get rid of the two I have marked - the centre one has a 7 style about it the left hand just goes to those panels I don't like the Shell well gives me a load of options I have no idea of what they mean.
I am intending slipping in a Samsung 850 and 7 anyway but for the mean time I have to use this version of 8 the machine came with.
    8 Pro desk 1 (SB) 7 Home desk 2 (IB) 8 Pro Lap 1
    Own build X 2 Desk X 1 Lap X 2
    i5 2500 & i5 3570K
    Gigabyte GA_H67UD3H-B3 & Asus P8Z77-V
    8GB (1333) 8GB 2400 set 1866
    NVidia GTX 650 X 2
    Xonar DG X 2
    Philips 24" (SB) Benq 24" (IB)
    Samsung 840 X 2 830 X 1
    Corsair HX 650 & HX 1050
    Coolermaster Centurion 2 & HAF XM
    Air (SB) LC (IB)
    M6980X X 2 (laser)M$ Sidewinder X4 & Sidewinder X6 (IB)
    Gigabyte M6980 X X 2 (laser)
    ADSL2
    Google
    Kaspersky ISS
    Two other machines Toshiba L550 Sat i5 CPU running 8GB RAM and Windows 8 Pro 64bit OS.
    Toshiba A200Celeron 4GB Win7 64bit
Ivo
158
This doesn't look normal. It is possible you have more than one start menu running at the same time. When Classic Shell is correctly installed, pressing the first icon should open the start menu (either in Windows 7 or Classic style, depending on your settings).
    Windows 7
Ok I will delete them and start again the very first one now lets me get properties up and I have a button that is rectangular with the shell icon the black and white one I cannot remove the blue one I unpinned it from the taskbar.
Am having great difficulties attaching pics too as it is not a matter of searching the Pictures I have to add that to some other setup why they changed it heaven only knows:(
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Thanks David I seem to recall using something similar on my Sandy Bridge if not the same site as soon as there emails have downloaded I will give it a go.:)
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
