Problem installing MS Office Home and Student 2007 on 8
Robert88
2
I tried installing my MS Office Home and Student 2007 on my new Windows 8 computer. The installation seemed successful, but I cannot locate MS Word 2007. On the Windows 8 Start screen there are images/icons for Excel 2007, Power Point 2007, One Note 2007, but not for Word 2007. I double clicked on the Excel 2007 image and it opened up the program OK. However, I cannot find Word 2007. I also looked in Windows Explorer and cannot find the Office Home and Student 2007 files. I would be grateful if someone could tell me how to find Word 2007 on my Windows 8 computer. It seemed to have been installed successfully (from the install disk), but I simply cannot find it. Thank you for any help.
Robert
    HP 500-164
jimbo45
Hafnarfjörður IS
4,373
Hi there
First check that you DID select word at install time (or simply uninstall and re-install).
Then on Windows start screen simply type Word and you should see it.
You can then click Pin to taskbar to get a quick link. To pin to desktop select open file location and on the file location simply select send to desktop (create short cut).
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Robert88
2
Hi Jimbo45,
thank you very much for your help! I was able to find Word and I pinned it to the taskbar as you suggested. Thanks again for the help - I really appreciate it.
Robert
    HP 500-164
