Solved problem formatting C drive
kkennyb
hi,
I created a Windows 8 recovery USB exactly as per tutorial.
i booted this and selected command prompt, i then tried to format C partition using the following command:
format C:/FS:NTFS it asked for volume label so i used VOL C: command and got volume label. i again used the format C:/FS:NTFS command and then entered the volume label exactly,it rejected it, i tried it many times,to no avail.
one thing though, the command prompt was system32> my system is 64 bit the way Windows works this probably not significant.
please advise.
ken
    Windows 8.1 64 bit PRO
    lenovo ideapad 320-141SK
    THIS MACHINE WAS PURCHASED WITH WINDOWS 10 HOME 64 bit,and i want to run windows 8.1 PRO 64 bit
cradom
S.E. Texas
You don't have any spaces in the command: Format Drive command
When it asks for a volume label it's asking for you to give it a name, for example 'Backup'.
    windows 8.1 64bit
    HP Pavillion 500-223
    8 gig
    SAmsung SyncMaster 2033
    1600x900
    Logitech G500S
kkennyb
when i said it asked for volume label it was more specific: "enter current volume label for drive C", after i'd entered the correct volume label it said "an incorrect volume label was entered for this drive"
i tried entering your example of BACKUP but it still said "an incorrect volume label was entered for this drive"
please advise
Ztruker
Space coast of Florida
Why not just format the drive during the install? No reason or need to do it ahead of time.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
kkennyb
maybe i've got it wrong, but during clean install,actually i'm restoring from a system image on an external HDD either way, i believe a full format is not executed, i want a full format, to destroy any remains of a virus infection that may still be lurking on HDD if i just did a clean install or restore image from an external HDD the virus could still be on the once infected HDD even after successful use of good anti-malware as a full format does not take place and the virus may re- emerge or so some paranoid people think me being one of them
please advise
Ztruker
The format you are doing is a full format, not a quick format as is done during install so ti does take a lot longer and does a better job of cleaning up.
If your concerned about virus/malware left over then you would be better off to use DBAN (Darrick's Boot and Nuke) to wipe the drive. It can take along time if it's a large drive but it gets rid of everything. You end up with a raw, allocated, unformatted drive. Just be careful using it. Make sure on the drive you want to wipe is connected so there is no chance of accidentally wiping the wrong one as happened recently in one of the other forums.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
kkennyb
thanks thats brilliant
