Solved Problem during installing updates
Hello frnds, When i check for windows update it shows 3 updates and one optional update is ready, but when i install them it always shows 0 byte and 0% completed. so how much time it take to install?
    windows 8 cp
windude99
USA
100
You will need to give it about 15 to 20 minutes. If it doesn't do anything, cancel the updates and open an administrative command prompt. In command prompt, type in sfc /scannow.
    Windows 7 Professional
    HP Pavilion P7-1010
    AMD Athlon X4 645 3.1ghz
    Foxxcon N-Alvorix RSS80
    6GB DDR3 1066
    Sapphire Radeon HD 5670
    Realtek Integrated Audio
    HP 2011x
    1600x900
    1. 128gb Crucial M4
    2. Seagate Barracuda 1tb 7200.12rpm
    3. Western Digital Caviar Green 1tb 5400rpm
    Seasonic 380b
    HP OEM
    Coolermaster Heatsink and Fan
    HP OEM
    HP OEM
    20 Megabits down/ 4 up
Thanx for answering, I spent 2hrs for installing but nothing happen then I tried ur suggestion and perform "sfc /scannow" command then I got this message "Windows Resource Protection did not find any integrity violation". Did I performed correct command if so then whats now?
    windows 8 cp
windude99
USA
100
You performed the correct command. The good news is that you don't have any corrupted Windows files. The bad news is that we still don't know what is causing this. I think you should try to system restore as shown in this tutorial: http://www.eightforums.com/tutorials/4692-system-restore-how-do-windows-8-a.html
    HP Pavilion P7-1010
    6GB DDR3 1066
    HP 2011x
    1600x900
    1. 128gb Crucial M4
    Seasonic 380b
    HP OEM
    HP OEM
    HP OEM
