Problem Booting after resizing partition
deyanimay
2
I previously had a windows 7 / 8.1 dual boot system but I was running out of room on my hard drive so I deleted the windows 7 partition and expanded the windows 8.1 partition using gparted. I then rebuilt the BCD from cmd using a recovery drive and was able to boot into windows. The problem is that when my computer starts and I log in to my account it says "preparing windows" and after like 15 minutes it finally gets me to a black screen where the only thing I can see is my cursor. I was hoping someone could help me get my computer working again. Thanks.
Edwin
1,759
@ deyanimay: welcome-
It might be trying to recover/repair the OS. You may have done things backwards, you should have re-configured the boot loader first then set defaults, then start deleting stuff.
You may have to clean install.
(There will most likely be more advice forthcoming, we love to help; check back periodically.)
Edit:
Maybe restart and get yourself to the Boot Menu with the appropriate F key.
My Computers
System One System Two
    Windows 7 Home Premium
    HP Pavillion
  • PC2
    Tablet - Windows 10 Home
deyanimay
2
If I boot into safe mode via cmd I can access the task manager. When I click file run new task and browser fore files my hard drive shows up as letter E instead of C could this be part of the problem?
