Print Spooler running but print messages advise otherwise
Budso
Sacramento
1
I have a fairly new PC computer running Win 8 64bit. Initial setup went off without a hitch. Wireless printers and such all worked fine.
Now, I select "print" from Microsoft Word, or Notepad, or any program for that matter, nothing happens, i.e. no print que, no printer page, nada. My control panel shows several printers installed. I have tried to delete all printers to start from scratch, however, the printer icons pop back up as quickly as I delete them.
I tried to install a newly purchased printer, but a message was returned stating, "no printer spooler service running" or something to that effect. I then opened the service page and turned the print spooler "on' in automatic mode. Nothing changed. It still returns a message about "Print Spooler not running", even though it is turned on in the services page!
I might add that this computer is part of a home sharing network with two other desktop PCs. They both perform flawlessly, interfacing wirelessly with the two HP printers on-line. The other desktops are running win 7 64bit.
I am truly out of airspeed and ideas. Thank you for your help.
Bud in Sacramento
    Windows 8 Professional 64bit
    Self Built
    Intel i5-3570K @ 3.4mhz OC 4.0mhz
    ASUS P8Z77-V Pro
    16GB Corsair
    NVIDA Ge Force GTX 570
    ASUS
    Dell U2311H
    Samsung SSD 830 series 250GB
    WD 1TB
    RAID w/2 Hitachi 2TB @ 5400RPM
    Corsair 750W Modular
    Noctua NH-D14
    Logitech
    Logitech M510
    Fiber Optic 10mbs/sec
    Chrome
    Windows 8 Defender
RichSl
29
I have the same issue on my laptop now...did you ever get to a resolution?
    win8 hopefully
    dell studio XPS 7100
    AMD Phenom II ii X6 1035T; 2600MHz
    6144MB; 1333MHz; DDR3
    (2) - both Seagate;
    New blank drive installed n PO-WDC WD1003FZEX-00MKZA0
    DVD drive: P1-HL-DT-ST DVD +/-RW GH5
    Back up drive on P2-ST31000528AS
    ie8
    macafee
    have replaced the memory board battery; loaded memory defaults and saved; install of win 8 Pro is painfully slow...WAY too slow. Takes over 10 min just to load splash screen.
