Precision Touchpad Double-tap and Drag - Turn On or Off
How to Turn On or Off Double-tap and Drag for Precision Touchpad in Windows 8.1
A certified Windows Precision Touchpad is a new class of input devices that provide high precision pointer input and gesture functionality. By default, these devices generate ultra-high precision scroll wheel messages for desktop application consumption.
The August 12th 2014 update rollup from Windows Update for Windows 8.1, Windows RT 8.1, and Windows Server 2012 R2 introduced a new feature for precision touchpads by adding the Double-tap and drag setting.
If this setting is turned on, you will be able to double-tap on an item using the precision touchpad while keeping your finger down on the second tap, then drag the item.
This tutorial will show you how to turn on or off the double-tap and drag feature of your precision touchpad for your account in Windows 8.1 and Windows RT 8.1.
Turn On or Off Precision Touchpad Double-tap and Drag in PC Settings
1. Open PC Settings, and click/tap on PC and devices on the left side. (see screenshot below)​
2. Click/tap on Mouse and touchpad on the left side, and do step 3 or 4 below for what you would like to do. (see screenshot below step 5)​
3. To Turn On Double-tap and Drag for Precision Touchpad
A) On the right side under Touch keyboard, move the Double-tap and drag slider to the right to turn on, and go to step 5 below.​
4. To Turn Off Double-tap and Drag for Precision Touchpad
A) On the right side under Touch keyboard, move the Double-tap and drag slider to the left to turn off, and go to step 5 below.​
5. When finished, you can close PC settings if you like.​
Turn On or Off Precision Touchpad Double-tap and Drag using REG File
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\PrecisionTouchPad
TapAndDrag DWORD
0 = Turn off double-tap and drag
ffffffff = Turn on double-tap and drag
2. To Turn On Double-tap and Drag for Precision Touchpad
Turn_On_Touchpad_Double_Tap_and_Drag.reg
3. To Turn Off Double-tap and Drag for Precision Touchpad
Turn_Off_Touchpad_Double_Tap_and_Drag.reg
5. Double click/tap on the downloaded .reg file to Merge it.​
6. If prompted, click/tap on Run, Yes (UAC), Yes, and OK to approve the merge.​
7. Sign out and in, or restart the PC to apply.​
