This tutorial will show you how to add or remove Power Saving Mode under Wireless Adapter Settings in Power Options for all users in Vista, Windows 7, and Windows 8.
Published by Brink
- ByLine
- How to Add or Remove Wireless Adapter Settings Power Saving Mode in Windows
- Synopsis
How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows
The "Power Saving Mode" option under the Wireless Adapter Settings section is used to configure how much power you want to save when using your wireless network card. There are four types of power saving modes available: Maximum Performance, Low, Medium and Maximum Power Saving. Your wireless network performance goes down with higher power savings. For example, choosing "Maximum Power Saving" will cause your wireless network connection to function at lower speeds.
This tutorial will show you how to add or remove "Power Saving Mode" under Wireless Adapter Settings in Power Options for all users in Vista, Windows 7, and Windows 8.
EXAMPLE: Wireless Adapter Settings "Power Saving Mode" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\19cbb8fa-5279-450e-9fac-8a3d5fedd0c1\12bbebe6-58d6-4636-95bb-3217ef867c1a
Attributes DWORD
1 = Remove
2 = Add
Attributes DWORD
1 = Remove
2 = Add
2. Add Wireless Adapter Settings "Power Saving Mode" to Power Options
Add_Power_Saving_Mode_in_Wireless_Adapter_settings.reg
3. Remove Wireless Adapter Settings "Power Saving Mode" from Power Options
Remove_Power_Saving_Mode_in_Wireless_Adapter_settings.reg
- How to Change the Power Plan Settings in Windows 7
- How to Change Power Plan Settings in Windows 8 and 8.1
- How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows
- How to Add or Remove "Allow sleep with Remote Opens" in Power Options in Windows 7 and 8
- How to Add or Remove "Console lock display off timeout" in Power Options in Windows 8 and 8.1
- How to Add or Remove "Dim display after" in Power Options in Windows
- How to Add or Remove "Enable forced button/lid shutdown" in Power Options
- How to Add or Remove "Hard disk burst ignore time" in Power Options
- How to Add or Remove "Hibernate after" in Power Options in Windows
- How to Add or Remove PCIe "Link State Power Management" in Power Options in Windows
- Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
- How to Add or Remove "System cooling policy" in Power Options in Windows
- How to Add or Remove "System unattended sleep timeout" in Power Options
- How to Add or Remove "Turn off hard disk after" in Power Options in Windows
- How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8
- How to Add or Remove "When sharing media" in Power Options in Windows
- 64-bit Windows 10
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom self built
- CPU
- Motherboard
- Memory
- Graphics Card(s)
- Sound Card
- Monitor(s) Displays
- 3 x 27" Asus VE278Q
- Screen Resolution
- 1920x1080
- Hard Drives
1TB Samsung 970 EVO Plus M.2,
250GB Samsung 960 EVO M.2,
- PSU
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Keyboard
- Logitech wireless K800
- Mouse
- Logitech MX Master
- Internet Speed
- Browser
- Internet Explorer 11
- Antivirus
- Other Info
Linksys EA9500 router,
Arris SB8200 cable modem,
Lumia 1520 phone
