Power Options - Add or Remove "When sharing media"
How to Add or Remove "When sharing media" in Power Options in Windows
The When sharing media setting in Power Options will let users configure power settings for when devices and computers are playing media from your computer to either allow the computer to sleep, prevent idling to sleep, or allow the computer to enter Away Mode.
This tutorial will show you how to add or remove the "When sharing media" setting under Multimedia settings in Power Options for all users in Vista, Windows 7, and Windows 8.
EXAMPLE: "When sharing media" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\9596FB26-9850-41fd-AC3E-F7C3C00AFD4B\03680956-93BC-4294-BBA6-4E0F09BB717F
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "When sharing media" from Power Options
Remove_When_sharing_media.reg
3. To Add "When sharing media" to Power Options
Add_When_sharing_media.reg
Windows 10 compatibility
Hi Brink,
Great forum here. Do you know if these reg edits will work for Windows 10? After googling around, it seems that the "When sharing media" option is often unavailable in Windows 10 systems that have touch screens.
Thanks,
Jacob
Hello Jacob, and welcome to Eight Forums. :)
I just tested this in Windows 10, and it will work in it as well.
