This will show you how to add or remove the Minimum processor state and Maximum processor state setting under Processor power management in Power Options for all users in Windows.
Published by Brink
- ByLine
- How to Add or Remove Minimum processor state and Maximum processor state in Power Options in Windows
- Synopsis
How to Add or Remove "Minimum processor state" and "Maximum processor state" in Power Options in Windows
The Minimum processor state is the minimum performance percentage your CPU will automatically decrease to save energy and battery life when there is little CPU demand by the system. You would want to keep this percentage the same or lower than the Maximum processor state setting.
The Maximum processor state is the maximum percentage performance your CPU will automatically increase to save energy and battery life when CPU demand increases. You would want to keep this percentage the same or higher than the Minimum processor state setting.
This tutorial will show you how to add or remove the "Minimum processor state" and "Maximum processor state" setting under Processor power management in Power Options for all users in Vista, Windows 7, and Windows 8.
If you enable virtualization in your BIOS or UEFI settings like below, then the Minimum processor state and Maximum processor state power options will not be available, even if you set them to be added.
Only when virtualization is disabled in BIOS/UEFI will Minimum processor state and Maximum processor state be available in your Power Options.
EXAMPLE: "Minimum processor state" and "Maximum processor state" in Power Options
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\893dee8e-2bef-41e0-89c6-b55d0929964c
Attributes DWORD
1 = Remove
2 = Add
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Minimum processor state" from Power Options
Remove_Minimum_processor_state.reg
3. To Add "Minimum processor state" to Power Options
Add_Minimum_processor_state.reg
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\bc5038f7-23e0-4960-96da-33abaf5935ec
Attributes DWORD
1 = Remove
2 = Add
Attributes DWORD
1 = Remove
2 = Add
2. To Remove "Maximum processor state" from Power Options
Remove_Maximum_processor_state.reg
3. To Add "Maximum processor state" to Power Options
Add_Maximum_processor_state.reg
- How to Adjust Processor Scheduling for Best Performance in Vista, Windows 7, and Windows 8
- How to Change the Power Plan Settings in Windows 7
- How to Change Power Plan Settings in Windows 8 and 8.1
- How to Add or Remove "Allow Away Mode Policy" in Power Options in Windows
- How to Add or Remove "Allow sleep with Remote Opens" in Power Options in Windows 7 and 8
- How to Add or Remove "Console lock display off timeout" in Power Options in Windows 8 and 8.1
- How to Add or Remove Desktop Background "Slide Show" in Power Options in Windows
- How to Add or Remove "Dim display after" in Power Options in Windows
- How to Add or Remove "Enable forced button/lid shutdown" in Power Options
- How to Add or Remove "Hard disk burst ignore time" in Power Options
- How to Add or Remove "Hibernate after" in Power Options in Windows
- How to Add or Remove PCIe "Link State Power Management" in Power Options in Windows
- How to Add or Remove "System cooling policy" in Power Options in Windows
- How to Add or Remove "System unattended sleep timeout" in Power Options
- How to Add or Remove "Turn off hard disk after" in Power Options in Windows
- How to Add or Remove "USB 3 Link Power Mangement" in Power Options in Windows 8
- How to Add or Remove "USB selective suspend setting" in Power Options in Windows
- How to Add or Remove "When sharing media" in Power Options in Windows
- How to Add or Remove Wireless Adapter Settings "Power Saving Mode" in Windows
- 64-bit Windows 10
- Computer type
- PC/Desktop
- System Manufacturer/Model
- Custom self built
- CPU
- Motherboard
- Memory
- Graphics Card(s)
- Sound Card
- Monitor(s) Displays
- 3 x 27" Asus VE278Q
- Screen Resolution
- 1920x1080
- Hard Drives
1TB Samsung 970 EVO Plus M.2,
250GB Samsung 960 EVO M.2,
- PSU
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Keyboard
- Logitech wireless K800
- Mouse
- Logitech MX Master
- Internet Speed
- Browser
- Internet Explorer 11
- Antivirus
- Other Info
Linksys EA9500 router,
Arris SB8200 cable modem,
Lumia 1520 phone
