Solved Power Icon and Log Off Icon not showing
Nuccii
Canada
1,950
In the elevated command prompt type sfc /scannow. It will take a while.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
topgundcp
San Jose - California
2,847
Symbol Font is missing in your PC. Download the attachement, extract it and right click on the file and select install.
In addition, you still have to re-run sfc /scannow to fix the problem with corrupted system files (Might have to run multiple times)
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Nuccii
Canada
1,950
In the same elevated command prompt run this Dism /Online /Cleanup-Image /RestoreHealth
Rerun the sfc command again then reboot the computer.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
5
Hi, thanks, but it says the font is already installed!
topgundcp
2,847
#8
The already installed font might be corrupted and causing display problem.
You have exact same problem with this post: http://www.eightforums.com/performance-maintenance/50421-small-boxes-problem.html
The OP in this post never came back and mark it solved which happens all the time once they got their problem sorted.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
5
#9
Hey thank you guys! this really helped!
Nuccii
Canada
1,950
#10
Your welcome
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
