Solved Power fail during upgrade assistant
Apriori
2
I ran upgrade assistant to upgrade from windows 7 to 8. I had paid for my upgrade and assistant was downloading my upgrade. It had got to 70% but was taking for ever due to my poor bandwidth, I live in the boondocks in Thailand. I left my computer running and went to bed, big mistake. The next morning I found that we had had a power failure during the night. I could not find my upgrade and running assistant again seems to want me to pay again. I don't know if everything downloaded before the power outage.
how do I recover my upgrade? Do I have to start again? If I do have to start again, how?
it seems that I am going senile. After turning my C drive inside out searching for the assistant I found a little shortcut on my desktop called install Windows as I hadn't seen this before I looked at its properties to find that it started the next stage of the upgrade. I now feel so stupid.
    Window 7
Ztruker
Go to your E-mail from Microsoft again, the one titled: Thanks for ordering Windows 8 (order # xxxxxxxxxx).
Click on the word here in this paragraph:
This is your receipt - make sure to print or save a copy for your records.
If you need to download Windows, write down your new product key and enter it here.
That will open the download window as follows:
Make sure you you follow to path to create media for installation at a later date, either DVD or a flash drive so you'll never have to do this again.
That same E-mail has a line near the bottom like this:
To always have the software as physical backup media at hand, order your personal backup DVD now. If your download link is so bad, perhaps that is a better way to get it.
Also shown here: http://www.eightforums.com/installation-setup/11002-how-redownload-your-windows-8-upgrade-setup-d-l.html
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
Apriori
2
    Window 7
