Power Driver State Failure
Wynna
Turning on the computer or after some time of use sometimes gives the BSOD power_driver_state_failure. after resetting it usually enters the windows. Could anyone help me with this problem?
softwaremaniac
2,480
Update drivers in red. Run System File Checker. Remove Alcohol 120 and/or Daemon Tools if using them.
[COLOR=red][B]HECIx64.sys Thu Sep 17 21:54:16 2009  (4AB293E8)[/B][/COLOR]
Intel Management Engine Interface
[URL="http://www.carrona.org/drivers/driver.php?id=HECIx64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]HECIx64.sys[/COLOR][/B][/URL]
[COLOR=red][B]NTIOLib_X64.sys  Wed Oct 20 08:45:49 2010 (4CBE901D)[/B][/COLOR]
MSI Afterburner driver (known  [COLOR=red]BSOD[/COLOR] issues with Windows) Also found to be a part of MSI  Live Update 5[br][br]Recently (Nov 2014) there have been numerous instances of  this driver in memory dumps. Analysis reveals that they are scattered throughout  the filesystem by the installed MSI command utilities. For now I suggest  uninstalling them all.
[URL="http://www.carrona.org/drivers/driver.php?id=NTIOLib_X64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]NTIOLib_X64.sys[/COLOR][/B][/URL]
Rt630x64.sys Fri May 10  11:59:08 2013 (518CC4EC)
Realtek PCI/PCIe Adapters
[URL="http://www.carrona.org/drivers/driver.php?id=Rt630x64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]Rt630x64.sys[/COLOR][/B][/URL]
intelppm.sys Thu Aug 22 10:46:35  2013 (5215CFEB)
Intel Processor driver
[URL="http://www.carrona.org/drivers/driver.php?id=intelppm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]intelppm.sys[/COLOR][/B][/URL]
agp440.sys Thu Aug 22 13:39:35  2013 (5215F877)
Intel AGP Bus Filter
[URL="http://www.carrona.org/drivers/driver.php?id=agp440.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]agp440.sys[/COLOR][/B][/URL]
nv_agp.sys Thu Aug 22 13:39:38 2013  (5215F87A)
NVIDIA nForce AGP Bus Filter
[URL="http://www.carrona.org/drivers/driver.php?id=nv_agp.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nv_agp.sys[/COLOR][/B][/URL]
RTKVHD64.sys Wed May 14 12:28:52  2014 (53734564)
Realtek High Definition Audio Function Driver
[URL="http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]RTKVHD64.sys[/COLOR][/B][/URL]
nvhda64v.sys Mon Jul 21 16:17:53  2014 (53CD2111)
nVidia HDMI Audio Device (nForce chipset driver)
[URL="http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvhda64v.sys[/COLOR][/B][/URL]
nvvad64v.sys Thu Sep 25 17:39:23  2014 (5424372B)
NVIDIA Virtual Audio Driver
[URL="http://www.carrona.org/drivers/driver.php?id=nvvad64v.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvvad64v.sys[/COLOR][/B][/URL]
[COLOR=red][B]NvStreamKms.sys Sat Nov 1 00:04:56 2014 (54541598)[/B][/COLOR]
nVidia Streaming Kernel service - may cause [COLOR=red]BSOD[/COLOR] in  Win8.1 systems (found in May 2014). Date/TimeStamp: Tue Apr 29 20:59:44 2014  (53604B00) [B]MAY NOT BE A PROBLEM, this is a tenative posting - Appears that  April 29 driver is a problem, July 2014 drivers seem OK[/B]
[URL="http://www.carrona.org/drivers/driver.php?id=NvStreamKms.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]NvStreamKms.sys[/COLOR][/B][/URL]
nvlddmkm.sys Wed Nov 12  21:51:31 2014 (5463C853)
nVidia Video drivers
[URL="http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys"]http://www.carrona.org/drivers/driver.php?id=[B][COLOR=blue]nvlddmkm.sys[/COLOR][/B][/URL]
Debug session time: Mon  Dec 22 04:37:56.517 2014 (UTC + 1:00)
Loading Dump File  [C:\Users\Mihael\SysnativeBSODApps\122214-20953-01.dmp]
Built by:  9600.17328.amd64fre.winblue_r3.140827-1500
System Uptime: 0 days 6:20:57.207
*** WARNING: Unable to verify timestamp for atapi.sys
*** ERROR: Module  load completed but symbols could not be loaded for atapi.sys
Probably caused  by : atapi.sys
BugCheck 9F, {3, ffffe00064a07610, fffff8026865faa0,  ffffe00066c8f010}
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000009F"]DRIVER_POWER_STATE_FAILURE  (9f)[/URL]
Bugcheck code 0000009F
Arguments:
Arg1: 0000000000000003, A  device object has been blocking an Irp for too long a time
Arg2:  ffffe00064a07610, Physical Device Object of the stack
Arg3:  fffff8026865faa0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe00066c8f010, The blocked  IRP
BUGCHECK_STR: 0x9F
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
FAILURE_BUCKET_ID:  0x9F_3_POWER_DOWN_IMAGE_atapi.sys
MaxSpeed: 2800
CurrentSpeed: 2793
BiosVersion = V17.4
BiosReleaseDate = 08/26/2011
SystemManufacturer  = MSI
SystemProductName = MS-7636
Debug session time: Sat Dec 20 14:34:37.525 2014 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\122014-18640-01.dmp]
System Uptime: 0 days  13:44:27.356
BugCheck 9F, {3, ffffe001ee409060,  fffff8039025faa0, ffffe001ef973b50}
Arguments:
Arg2:  ffffe001ee409060, Physical Device Object of the stack
Arg3:  fffff8039025faa0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe001ef973b50, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2800
CurrentSpeed: 2793
BiosVersion = V17.4
Debug session time: Sat Dec 20 00:49:30.525 2014 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\121914-49109-01.dmp]
System Uptime: 0 days 1:24:38.794
BugCheck 9F, {3, ffffe00199a28060, fffff800fa25faa0,  ffffe0019bb95460}
Arguments:
Arg2:  ffffe00199a28060, Physical Device Object of the stack
Arg3:  fffff800fa25faa0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe0019bb95460, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2800
CurrentSpeed: 2793
BiosVersion = V17.4
Debug session time: Fri Dec 19 14:16:15.526 2014 (UTC + 1:00)
Loading  Dump File [C:\Users\Mihael\SysnativeBSODApps\121914-47281-01.dmp]
System Uptime: 0 days  19:45:41.884
BugCheck 9F, {3, ffffe000e1615610,  fffff8021b2aaaa0, ffffe000e0b254f0}
Arguments:
Arg2:  ffffe000e1615610, Physical Device Object of the stack
Arg3:  fffff8021b2aaaa0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the  Functional Device Object of the stack
Arg4: ffffe000e0b254f0, The blocked  IRP
BUGCHECK_STR: 0x9F
MaxSpeed: 2800
CurrentSpeed: 2793
BiosVersion = V17.4
--- E O J --- 2014 Dec 22 10:04:01 AM _88-dbug Copyright  2012 Sysnative Forums
    Windows 10 Pro x64
    INTEL Core i7-2700K 3.5GHz
    ASROCK Fatal1ty P67 Main Board
    HyperX Blu 8GB (2 x 4GB) DDR3 1600
    Gigabyte GTX 980 Ti G1 Gaming
    On-board
    Philips Brilliance BDM4065UC
    3840x2160
    SSD: Samsung EVO 250 GB
    Internal HDD: WD Black 1TB
    External: 2x2TB MyBook drives
    1x4TB MyBook
    1x1TB Seagate Freeagent drive
    Corsair GS 700W
    Silverstone Kublai KL04
    Artic Cooling Freezer Pro
    Logitech G710+
    Razer Mamba Elite 2012
    FF 39.0.3, Microsoft Edge, Chrome 44
    Avast 10.0
blueelvis
OMG Debugger!
India
2,097
Hi Wynna & Welcome to the forums ^_^,
I have analysed your dump files and below has been provided an analysis for informative purposes :-
0: kd> !irp ffffe001ef973b50
Irp is active with 5 stacks 2 is current (= 0xffffe001ef973c68)
 No Mdl: No System Buffer: Thread 00000000:  Irp stack trace.
     cmd  flg cl Device   File     Completion-Context
 [  0, 0]   0  0 00000000 00000000 00000000-00000000
   Args: 00000000 00000000 00000000 00000000
>[ 16, 2]   0 e1 ffffe001ee409060 00000000 fffff8008b0c3440-ffffe001ee5e8810 Success Error Cancel pending
       Unable to load image \SystemRoot\System32\drivers\ataport.SYS, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ataport.SYS
*** ERROR: Module load completed but symbols could not be loaded for ataport.SYS
 \Driver\[COLOR=#0000FF][B][U]atapi[/U][/B][/COLOR] CLASSPNP!ClasspPowerUpCompletion
   Args: 00051100 00000001 00000001 00000002
 [ 16, 2]   0 e1 ffffe001ee5e82d0 00000000 fffff8008a41fc08-00000000 Success Error Cancel pending
        \Driver\disk partmgr!PmPowerCompletion
 [ 16, 2]   0 e1 ffffe001ee5e7040 00000000 fffff8038e936c30-ffffe001ef25e010 Success Error Cancel pending
        \Driver\partmgr nt!PopRequestCompletion
 [  0, 0]   0  0 00000000 00000000 00000000-ffffe001ef25e010
So, the driver "ATAPI.sys" is the one who is blocking the IRP packets which in turn leads to the System Crash. This driver is the "ATAPI IDE Miniport driver" and is a part of the operating system. Since, it is a part of Windows, the chance of it being at fault is extremely less. So, it could mean that there is something 3rd party which is causing the trouble. Let's take a look at your 3rd party drivers now -
**************************Mon Dec 22 09:07:56.517 2014 (UTC + 5:30)**************************
[B][U]HECIx64.sys                 Fri Sep 18 01:24:16 2009 (4AB293E8)[/U][/B]
[COLOR=#FF0000][B][U]NTIOLib_X64.sys             Wed Oct 20 12:15:49 2010 (4CBE901D)
[/U][/B][/COLOR]Rt630x64.sys                Fri May 10 15:29:08 2013 (518CC4EC)
intelppm.sys                Thu Aug 22 14:16:35 2013 (5215CFEB)
RTKVHD64.sys                Wed May 14 15:58:52 2014 (53734564)
nvhda64v.sys                Mon Jul 21 19:47:53 2014 (53CD2111)
nvvad64v.sys                Thu Sep 25 21:09:23 2014 (5424372B)
NvStreamKms.sys             Sat Nov  1 04:34:56 2014 (54541598)
nvlddmkm.sys                Thu Nov 13 02:21:31 2014 (5463C853)
**************************Fri Dec 19 18:46:15.526 2014 (UTC + 5:30)**************************
agp440.sys                  Thu Aug 22 17:09:35 2013 (5215F877)
nv_agp.sys                  Thu Aug 22 17:09:38 2013 (5215F87A)
**************************Sun Dec 14 00:41:47.591 2014 (UTC + 5:30)**************************
hiber_ataport.sys           Thu Aug 22 17:09:53 2013 (5215F889)
http://www.carrona.org/drivers/driver.php?id=hiber_ataport.sys
I have highlighted a driver in RED. It is known to cause problems with some Windows systems. Kindly uninstall any MSI product (MSI Afterburner/ MSI Live Update 5) from your system.
Update your Intel Chipset drivers and Intel Management Interface drivers.
I found that your BIOS is very old -
  BIOS Version                  V17.4
  BIOS Release Date             [B][U]08/26/2011[/U][/B]
  Manufacturer                  MSI
  Product Name                  MS-7636
Kindly see if there is any available update for the motherboard. If there is any update available then report back but DON'T DO the BIOS update as of now since it can permanently damage your motherboard if not done right.
Also, was this problem occurring before you migrated to Windows 8.1?
Let me know how it goes ^_^
-Pranav
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
Wynna
Thanks for the responses.
I used the Windows 8.1 on this computer for about a year without any problem either, so he had to be formatted and then a few days later began the BSOD.
I performed the following procedures:
- Run SFC / Scannow and no errors were found.
- Do not have Alcohol 120 and / or Daemon Tools installed.
- I installed the Intel Update and said there was no available updates.
- Stopped the nVidia Kernel Streaming service.
- Uninstalled the MSI Live Update.
- Updated the drive Realtek PCI / PCIe Adapters.
- Realtek High Definition was already installed the latest version of the available drive.
- Vidia Video drivers were already installed the latest version of the available drive.
- Windows Update showed no new updates.
- Not a new BIOS available.
The computer did not error in the last 24h. But the BSOD does not always happen. If within a few days there are no new errors as put the topic as solved, but post the new error.
Thanks again.
blueelvis
OMG Debugger!
India
2,097
Sure thing. Keep us updated ^_^
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
Wynna
I came back.
The BSOD stopped. No blue screen appeared again. But sometime my monitor off for three seconds and when it returns the following message appears. "Display NVIDIA Windows Kernel Mode Driver Driver, Version 344.75 stopped responding and has successfully". and the computer functions normally until the error again.
Could anyone help me? Sorry if it is not the right place to ask.
softwaremaniac
2,480
Update your GPU drivers.
    Windows 10 Pro x64
    On-board
    3840x2160
    1x4TB MyBook
    Corsair GS 700W
    Logitech G710+
    Avast 10.0
blueelvis
OMG Debugger!
India
2,097
#8
I came back.
Hi Wyna ^_^,
I am glad to hear that the problem related to BSOD has been solved.
The error you are experiencing is regarding the Display Driver not receiving a response from the Graphics Processing Unit in a timely manner and hence you are seeing Windows reset the adapter automatically.
Use the Display Driver Uninstaller from this **LINK**. Once you have successfully removed the current version of the NVIDIA Driver, try different versions of the driver like try a driver which is a bit old, or the latest BETA Drivers.
-Pranav
    Toshiba
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
