Power and Sleep Settings Shortcut - Create in Windows 8.1
How to Create a Power and Sleep PC Settings Shortcut in Windows 8.1
Power and Sleep in PC settings is where you can manage adaptive brightness, turn off the display, and sleep after.
This tutorial will show you how to create or download a Power and Sleep shortcut that opens directly to PC settings in Windows 8.1 and Windows RT 8.1.
EXAMPLE: Power and Sleep PC settings
To Download a "Power and Sleep PC settings" Shortcut
Power_and_Sleep_PC-settings_Shortcut.zip
3. Open the .zip file and extract (drag and drop) the shortcut to your desktop.​
4. Unblock the extracted shortcut.​
6. When finished, you can delete the downloaded .zip file if you like.​
To Manually Create a "Power and Sleep PC settings" Shortcut
1. Right click or press and hold on an empty area of your desktop, and click/tap on New and Shortcut.​
If you do not have a US English Windows 8.1 installed, then you will need to change the en-US folder name in the command below for the folder name with your language instead for this to work.
%windir%\explorer.exe %localappdata%\Packages\windows.immersivecontrolpanel_cw5n1h2txyewy\LocalState\Indexed\Settings\[COLOR=#ff0000][B]en-US[/B][/COLOR]\AAA_SettingsGroupPowerAndSleepDisplayOff.settingcontent-ms
3. Type Power and Sleep PC settings for the name, and click/tap on the Finish button. (see screenshot below)​
4. Right click or press and hold on the new Power and Sleep PC settings shortcut, and click/tap on Properties.​
6. In the line under "Look for icons in this file", copy and paste the location below, and press Enter. (see screenshot below)​
%SystemRoot%\system32\powercpl.dll
  • Power_and_Sleep_PC-settings_Shortcut.zip
