Please help!!!!!
LOVE8
Hi,
I am having a problem being that my screen resolution will not under any circumstances get higher than 600 x 800px (even under unsupported resolutions) I have tried Pheonix etc and nothing will get it to the right resolution, with Pheonix I was able to get it higher but not right, my native resolution is 1920 x 1200 but I keep it at 1440 x 900.
I am currently running Windows 8 Build 7989/Windows 7 on Dual Boot I was having the same problem on windows 7 before but simply installed the latest ATI driver and the problem was fixed, the current driver is "Generic non-PnP Monitor"
Is there any way for me to get either a up-to-date driver or force the resolution?
Thank you all in advance.
    Windows 8 Pro, Ubuntu 12.10, Backtrack Linux
    Dell Inspiron 17R N7110
    Intel i5-2410M @2.30 GHz
    6 GB
    1600x900
    25 Mbps
Coke Robot
Gold Member
You could try downloading the latest ATI driver and try installing it in Windows 7 compatibility mode.
I had something like this with a wifi adapter and it wouldn't install without changing compatibility to Windows 7, after that, it worked!
Also, you may or may not get it working due to the fact it's still an alpha build and it's not close to finalization.
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
LOVE8
I tried but it said: "2) Your hardware version or OS could not be determined" I will try again...
    6 GB
    1600x900
    25 Mbps
LOVE8
No luck... :sad::help:
    6 GB
    1600x900
    25 Mbps
