Peerblock would not load at startup
Anusha
It shows up in Task Manager's start up app list. But it doesn't load up at Windows startup. It does require UAC. But even when I turn off UAC, if still doesn't start automatically. I have to manually load it.
Is there a fix? Or we cannot simply load apps that require elevation at startup?
    Windows 8.1 Pro x64
    DIY
    Intel Core i7 4790K @4.5GHz
    Asus ROG Maximus VII Gene
    16GB A-DATA DDR3-2400
    Gigabyte GTX 970 Gaming G1
    QNIX QX2710
    Samsung 840 series 250GB
    Toshiba DT01ACA300 3TB (Data)
    Western Digital Caviar Green WD30EZRX-00DC0B0 3TB (Backup)
    Silversonte G series 750W
    Silverstone Sugo SG09
    Noctua NH-U12S
    Generic
    Logitech G602
    200Mbps/200Mbps Fibre
Anusha
I found this on their website.
This must do the trick. Cannot check since I'm not at home. Will reply back.
User Account Control
    Windows 8.1 Pro x64
    DIY
    QNIX QX2710
    Noctua NH-U12S
    Generic
    Logitech G602
