PC Settings-Product Key. Window keeps opening on its own.
Do any of you guys who had Win8 preinstalled on your new computers have the problem of the PC Settings window keep opening up on its own. The right-hand side of the window states: 'This Product Key doesn't work.........etc. The bottom of the window states that it should have come with an email on purchase of the computer.
When I query this with both Acer & Windows they tell me that the Product Key no. is in the BIOS. That's all well & good but how do I stop this window continually opening?
    Windows 8.1 and 10, 64-bit 9600 Multiprocessor Free
    Lenovo Yoga Pro 1370 (Ultrabook)
    Intel (R) 5Y70 @ 1.10GHz
    Lenovo VIUU4
    8GB
    Intel (R) HD Graphics 5300
    High Definition Audio Device
    3200 x 1800
    256GB SSD
    Samsung MZNTE256HMHP-000L2
    Fan
    Windows Defender, Ccleaner, Malwarebytes.
    Touchscreen,
Can you post a screen shot of the window ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
popeye
United States
3,090
With UEFI it is embedded in the bios. Almost sounds like you have a virus. With 8 you have the reset option.
Oh, and UEFI is not BIOS, BIOS is BIOS and UEFI is UEFI. :p
P.S. Does your System page show it is activated?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
alphanumeric
slightly off center
Gold Member
The product key is embedded in the BIOS on a PC that comes with Windows 8 preinstalled at the factory. Activation is done online though. Where did you buy your PC and what make and model is it. The embedded code would be done by Acer assuming it shipped from the factory with Windows 8 preinstalled. If you bought it from another retailer that's reselling it, and they upgraded it from say Windows 7 to 8, there would not be an embedded code for Windows 8. In that case there should be a COA sticker on it somewhere, usually hidden under the battery. What's on it in the way of stickers?
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
My Win8 must have been installed at the factory & not by the retailer I bought it from, because it has a touchscreen.
How is 'activation' of the Product Key done online? Here's a screenshot of the page that opens periodically. There's no label.
    Lenovo VIUU4
    8GB
    3200 x 1800
    256GB SSD
    Fan
    Touchscreen,
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
alphanumeric
slightly off center
Gold Member
Microsoft changed things around with Windows 8 with regards to OEM activation. When I say OEM I'm referring to Dell, Acer, HP etc. PC's with Windows 8 installed at the factory use an embedded product code. Its coded into the motherboard. They also activate online where as with Windows 7 and earlier operating systems they didn't. Each PC now has its own unique product code. In the past all Dells would use the same master code, and all HP's would use their same master code etc. Now even OEM PC's with Windows 8 preinstalled activate online with the Microsoft activation servers. You have some kind of activation error. Either your key has been blocked (blacklisted) or your system has some files messed up that deal with activation status. If it shipped right from the factory with Windows 8 its likely a file system problem. If it didn't ship with Windows 8 and it was upgraded by somebody along the way, the install may not be legal. It sounds like its either an activation server glitch of a file system error on your PC. I'll let one of those IT guys that more about it help you sort that out.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
#8
David, I clicked on the vbs script & tried to open it, but I'm getting a security warning from McAfee. Please advise.
    Lenovo VIUU4
    8GB
    3200 x 1800
    256GB SSD
    Fan
    Touchscreen,
#9
It is safe to run.
Trust me.
I would not send you or anyone something harmful.
All it does is show your product ID & product Key.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
#10
When you run it a tiny window pops up with your ID & product key:
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
#11
I clicked on the link David & yes the product key no. was shown. I inserted it into the 'PC Settings Activate Windows' box it ran a check for a while & then nothing. I thought the problem was solved & I'm back to square one!
    Lenovo VIUU4
    8GB
    3200 x 1800
    256GB SSD
    Fan
    Touchscreen,
#12
You have a bogus product key.
Illegal. :(
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
DavidY
Active Member
955
#13
Illegal. :(
Yeah but this isn't the only thread on here recently about legitimately bought product keys that have stopped working - and bearing in mind the OP's PC is a pre-installed Windows so not easy to fake.
My suspicion is that Microsoft have messed up somehow, and are blacklisting legitimate keys.
    Windows 8.1, 10
alphanumeric
slightly off center
Gold Member
#14
David, how do we know if the "Installed Key" is the same as the embedded key? If I run that script on my laptop it shows my Media Center key not the embedded factory key. In robinpe's case the script is just reading the key his PC is currently using and failing to activate with. How do we know if its actually the embedded key? It should be, but is it?
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric
slightly off center
Gold Member
#15
Illegal. :(
It could be a Microsoft Activation server glitch. With the new OA3 that Windows 8 uses activation is done online.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
#16
Illegal. :(
Best thing to do is contact Microsoft.
Provide them with ID # & Product key & see what happens.
Microsoft Product Support Customer Phone Number | Shortest Wait | Best Support | GetHuman.com
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
alphanumeric
slightly off center
Gold Member
#17
Illegal. :(
:ditto: :thumb:
    Asus
    Thermaltake TR 620
    Stock heatsink fan
#18
The ID & Key I get when I run it on my PC is the same as the Key & ID I purchased from Microsoft.
What else can I say.
If I'm missing something, enlighten me for everyone's benefit.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
alphanumeric
slightly off center
Gold Member
#19
You haven't upgraded, I have. I upgraded to 8 Pro and then added Media Center. Each time I enter a new product code and that new code becomes the one my PC activates against. When I run the script it reads my Media Center key as that's the one my PC is using and activating against. When I noticed that it occurred to me that in robinpe's case, it was just going to read the code that's not working for him and that that "may" not actually be his embedded code. It should be but there is no way to tell for sure. It was just an observation. He in effect just typed the same not working product code back in.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric
slightly off center
Gold Member
#20
David, Please don't take what I said the wrong way, it was good idea. And I didn't mean to imply that you don't know what your doing or anything. It might sound like that but that wasn't my intension.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
