PC drops wifi connection when TV gets power (hdmi)
Sitara876
greetings!
i have found a few threads here that describe problems similar to mine, but nothing exactly. i've also used those threads to do a bit of troubleshooting, but nothing has worked.
i connect to wifi on my computer, it works fine, no problem. my tv is connected to my pc via hdmi. i get video and audio fine on my tv when i'm using it through my pc. the problem is when my tv gets power, the wifi on my pc drops, and it stops recognizing all of the wireless networks in the area that are normally on the list. it still will see my network, as it is set to automatically connect to it, but when i try to connect while the tv has power, it will not. it's not just when the tv gets turned on, but when it actually gets power, when it gets plugged in to the wall socket. when i unplug the tv, all of the wireless networks pop back up on my list, and i can connect to mine with no problems.
i'll also note that when my tv has power, and i have no wifi on my pc, i still do have wifi on my phone. the router is about 10 feet from me, in another room.
my network adapter is a Qualcomm Atheros AR9485 Wireless Network Adapter and i'm running windows 8.1. tv is a toshiba, not a smart tv.
uninstalled and installed newest drivers for the network adapter. it's set to not turn off the adapter to save power and it's set to high performance. i've run the troubleshooters both when the tv has no power/pc has wifi, and when the tv has power/pc has no wifi. it always says there is nothing wrong with the adapter.
any help or ideas would be much appreciated!
popeye
Welcome to the forum!
Your post is a bit confusing. You talk about HDMI and WiFi which have nothing to do with each other. Plugging in HDMI to the TV should have no affect on your WiFI unless you have a computer hardware problem.
Also no mention of router make/model. Computer make/model would be nice too.
Going by what you describe with the TV it sounds like your computer's HDMI port is messed up. Have you tried different HDMI cable?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
broe23
Retired from the grind
The only thing I can think of is either too long of a connection, or a huge draw of power. You could always go with a Miracast streamer stick, or try Chromecast.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
yu gnomi
I don't know what OP's issue is either, but I have a Chromecast dongle on my TV and it works great. They are fairly cheap too (around $30 on Amazon).
    Win 8.1 Pro
    Intel i5-4590
    MSI h97 PC Mate
    Kingston Valu Ram 2 x 8 gb
    Radeon r7 265
    Viewsonic 22" flat display
    Samsung 250 gb 840 evo SSD,
    WD Blue 1 TB HD,
    Fantom 2 TB ext HD
    Corsair 600 W
    Antec 1
    stock CPU cooler, 4 x case fans, GPU fan and P/S fan
    HP ps/2 keyboard
    Logitech Trackman Marble
    50 mb/s
    Chrome
    Norton Security Suite
