Patch Panel Help
COKEDUDE
I apologize if this is something easy. I have never used a patch panel before. No matter what I try I am not able to get an internet connection through the patch panel. This is a panduit dp5e patch panel. I have tried running a cable from the router to patch panel. I have tried running a cable from the switch to the patch panel. Neither method work. I have noticed that the lights do not turn on either way. Is this patch panel supposed to have some kind of power supply for the lights? I do not see a way to plug it in. Am I missing some part I need? The router and switch both work fine.
