Overlocked to 4.5Ghz but maximum speed only hits 4.41 Ghz
jago86
FX 6300 overlocked from 3.5 to 4.5Ghz but windows shows that the speed never goes above 4.41Ghz
The utilization is at 26% in the screenshot below but I've had it at 99% and still didn't peak above 4.41Ghz.
What do you guys think?
    Windows 8.1 Pro x64
    My Build
    AMD FX 8350 4 Ghz (Stock speed) 95W
    ASUS Sabertooth 990FX R2.0
    Kingston 16GB DDR3
    MSI TwinFrozr III nVidia GTX 680 2GB
    RealTek HD Audio - Logitech THX Z906 5.1 Surround Sound - 500W
    Samsung 32" LCD Television - LN32D405E3D
    1360 x 768
    Samsung EVO 840 (OS)
    Seagate 500GB (Miscellaneous) 7200rpm SATA 6
    Hitachi 500GB (Games) @ 7200rpm SATA 6
    Hitachi 1TB (Downloads) 7200rpm SATA 3
    Cooler Master 800W
    Corsair HAF XM
    Corsair H80i
    Klip Xtreme Multimedia- KMM 101E
    Genius Maurus
    100 Mbit/s
    Opera / Chrome
    Symantec Endpoint
    i love wantons, sushi, fruit cocktail, pistachio gelato and lemon sorbet
    F1 Savant
blueelvis
OMG Debugger!
Hi Jago86 ^_^,
Personally, I don't trust the values of Task Manager when it comes to CPU. Earlier when I had Windows 8, my CPU maxed out at 3.0GHz (Due to Turbo Boost) and it was visible in the Task Manager, but when I installed Windows 8.1 , the Task Manager shows my default speed (2.4GHz) and does not show that my processor is being overclocked due to Turbo Boost.
But, when I run CPU-Z , I see that my CPU Frequency goes till 2.996GHz which is very close to 3.0GHz . I would suggest you to check CPU-Z for a more accurate reading.
-Pranav
    Windows 8.1 Industry Pro B-)
    Toshiba
    Core I5 2430M @ 2.4GHz
    Intel HD 3000 B-)
    1366x768
    Toshiba 500 GB
CountMike
Another question is how you OCed ? Did you leave anything on auto ? Voltages, power saving etc. ? All of these ca slow processor down. LLC can keep voltage down and so it would limit OC to some extent.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
IF it shows correctly in CPUZ Bench Test it should also show correctly in Windows Properties. I have same issue.
    Windows 8.1, Windows 7 Ultimate, Windows 10, Linux Mint and more
    ASUS
    AMD 3800X, Intel 6900K
    X99 E-WS USB 3.1, CROSSHAIR HERO VIII
    128 GB CORSAIR DOMINATOR, 32 GB TEAM GROUP T FORCE
    NVIDIA 1070, SAPPHIRE RX 590 NITRO+
    ONBOARD
    SAMSUNG 32"
    4K
    :::GRINS::: SERIOUSLY?
    CORSAIR 1000 W PLATINUM
    THERMAL TAKE / AZZA
    NOCTUA / CM
    LOGITECH PRODIGY
    LOGITECH
    1 GBs
    FIREFOX
    KASPERSKY
    PC builder. Own a dozen PCs / built hundreds. All of us have a lot to learn. Some of us stand to learn more than others and those who think they know the most generally know the least. I'm here to learn and pass on what little I know.
As an after thought 4.5 GHz could be your target speed. CountMike makes a valid point about leaving something in "auto" mode in UEFI. IF your stock speed is 3.5 GHz you're already achieving an excellent o.c. I'm curious as to what sort of cooling you're using.
    ASUS
    ONBOARD
    SAMSUNG 32"
    4K
    THERMAL TAKE / AZZA
    NOCTUA / CM
    LOGITECH PRODIGY
    LOGITECH
    1 GBs
    FIREFOX
    KASPERSKY
